M105 and M205 On white Jeep Liberty
  • M105 and M205 On white Jeep Liberty
    M105 on 6.5" Yellow pad followed by M205 on 6.5" Beige pad and topped with NXT 2.0.
    Re: M105 and M205 On white Jeep Liberty
    Looks good. Try taking some pics in the sun and post them up for us to see!
      It's White.. So We lose for depth due to that, if it was black it wouldn't matter.
        Of course!
        The car is looking great
          Of course!
          Thanks.
            Maybe so, but what you lose in depth you make up for with brilliance! And direct sun shots don't lie!! The Jeep looks great in either light, though, and you did an outstanding job all around!
              Thanks Mike, that means a lot.
                Mike,
                I finally tried Ultimate Wax Liquid tonight, applied it over the existing the existing (NXT 2.0) and I have to say I think it's even shinier that it was before, and even wetter looking.
                Applied it by hand using a 4" black soft buff finishing pad with a handle on it one section at a time and buffed it off, worked great.
                Long time NXT 2.0 user here, and finally finished off the bottle the other day, have a new bottle also along with the Ultimate Wax Liquid.
                  If you like NXT you would definitely like M21. But you can't go wrong with UW or NXT.
                    Used to use M26 a very long time ago before I went over to NXT.
                    Never tried M21 though.. Hmmmm.
                      M21 is the "professional" version of NXT - they are virtually identical.
                        Figured that one.
                          My bad. I confused M21 and M20. But yes M21 is the pro version of NXT.
                          Found this from Mr. Stoops
                          First, to the original question: M21 Synthetic Sealant 2.0 vs Ultimate Wax - Both are 100% synthetic polymer sealants and both contain hydrophobic polymers. But they don't contain the same polymers so they aren't the same product just in different bottles. Ultimate uses our "thin film" technology which becomes immediately understandable the first time you use it - it goes on super thin and in liquid form it won't stain plastic trim. Ultimate liquid is the only wax/sealant we make that can either be allowed to dry for a bit before removal or wiped off right away with no change in performance. In some cases it actually works better if it's applied to a panel at a time and then wiped off before proceeding to the next panel. This is true especially on darker colors where a slightly heavy application can lead to an uneven appearance. M21 should be applied to all painted surfaces of the vehicle and allowed to dry fully before wipe off. Back to the polymers contained in these two products - M21 is very similar to NXT Tech Wax 2.0 in so much as they both use the same hydrophobic polymers but M21 has been slightly tweaked to better handle rotary application.
                            Thanks for the info.
                            Just wish they would come out with a Pro version of Ultimate Wax.
                            I find there is a very noticeable difference between NXT 2.0 and Ultimate Wax, specifically on white. More clarity of the reflections and depth and even more of a wet look over NXT 2.0.
                            Been using UQW as a test after NXT and there was a noticeable improvement so I went ahead and got Ultimate Wax and the difference was mind blowing to me...
                            Will take photos once I get some sun.....
                            Basically the finish on my Jeep is now:
                            NXT 2.0 - 2 coats followed up with Ultimate Wax - 2 Coats.
                            The surface prep is import though I think, M105 followed by M205 to get the results that I am seeing, M205 with a 6.5" Beige pad really set up the finish.
                              I posted the photos in the Consumer line here:
