Does anybody have any pictures of interior door panels/dashboards dressed with water based dressing ? Straight or 1:1..either or. id like to see what the dressing looks like on interior parts..thanks in advance. i appreciate if anybody has pics to post
Water Based Dressing - any pictures ?
Re: Water Based Dressing - any pictures ?
Originally posted by roushstage2 View PostWater Based Dressing comes out looking just like Hyper Dressing. I have some somewhere...I think.
by the way, is WBD thick in its consistency ? hyper dressing, even diluted 1:1 is very thin and it makes it a bit hard to apply it to dashboards and panels without making a mess of your fingertips..hyper dressing sorta just goes right through the foam..hows WBD when its used straight? as i intend to use it for high glossAddicted
I will have to go through quite a bit of pictures, lol, but I'll check and see what I can find then. WBD straight is kind of on the thicker side. It has the same consistency as straight HD. Use WBD straight for high gloss or 1:1 for low gloss. Since you want high gloss, I think WBD is going to be about as thick as you can get without actually using a gel-type/thicker product (like NXT Tech Protect).
Originally posted by roushstage2 View PostWBD straight is kind of on the thicker side. It has the same consistency as straight HD.
really?
if WBD has the same consistency as HD straight, then thats pretty decently thick and exactly what i want..tyler thanks for the info i appreciate it a lot, i think i am going to pick up some now.
and if you can find those pictures i greatly appreciate it.
Thanks again broAddicted
Originally posted by roushstage2 View PostI went and shook both jugs just to check before I posted that for sure.I'll look for those pictures in the morning. I have a few thousand to go through.
my problem with Hyper Dressing on interiors, is that its too thin..hyper dressing obviously isnt meant to be used straight, the closest you can go is 1:1 and when i want to spray that onto my applicator pad, its so thin that the product just goes right through the pad and onto my fingertips and just gets really messy...i never have this problem with SSP though, weird i know...so i was hoping for a product that is thicker for interiors, while i love HD for wheel wells, engine bay, its just not cutting it for me for interiors in the way that it applies to the surface..so since you say WBD straight out of the bottle is as thick as hyper dressing straight, then i think thats perfect for me. im not looking for a product as thick as Endurance tire gel, but just not thin like water. probably something as thick/thin as NXT Tech Wax 2.0..its got that feel of a wax but is much thinner which helps a lot with applying it...so if WBD is anything close to that, then i think i found a winnerAddicted
If you want something with wax-like consistency, the only thing that would be close to that is the discontinued M38. One thing I do when I don't want product getting on my hands is to use some disposable gloves. I almost always have a box for when I work on my cars.
I believe that was full strength. I looked through all of my other pictures, but I must have deleted what other ones I had of it. If you want, when the sun appears again later this week, I can wipe the dash down for you and take a couple of more pictures. Your call. I think it needs to be re-wiped anyways.
Originally posted by roushstage2 View PostI believe that was full strength. I looked through all of my other pictures, but I must have deleted what other ones I had of it. If you want, when the sun appears again later this week, I can wipe the dash down for you and take a couple of more pictures. Your call. I think it needs to be re-wiped anyways.
id like to see what WBD dressing at full strength looks like applied and left to dry, no wiping down for a final wipe..i appreciate it that man. even a picture with not much sunlight and just a camera flash is enough for meAddicted
