Body Solvent
  • #31
    Re: Body Solvent
    I've had much better success with Meg's Body Solvent when I let it dwell for 30 minutes or more. Usually I'll wash the area first, with soap, rinse, then apply the Body Solvent before I go to work on the wheels. That usually takes at least 30 minutes, if not an hour. Then I return to the bug infected area and use a soapy bug sponge with the Body Solvent having done it's work for 30 minutes (+). Finally, I'll rewash with soap again to remove all of the Body Solvent.
    I'll have to agree, it's not their best product.
    • #32
      Re: Body Solvent
      Whats with all the Body Solvent bashing.
      You have to use the product correctly in order for it to work.
      Much better than many OTC products as well.
      • #33
        Re: Body Solvent
        I like it.
        • #34
          Re: Body Solvent
          I don't know if saying it didn't work is bashing it...
          I sprayed the sap down twice, liberally, with it and let it sit several minutes each time and it didn't do anything. Maybe it's just tree sap? If it is anything like my missing Gold Class Bug and Tar Remover, then I'm sure it works superbly on bugs and tar.
          • #35
            Re: Body Solvent
            not bashing at all bro, the reason i got a gallon of this stuff was bc of you after reading your reviews and reading all of your car details i had to go out and buy it. i said if tuck uses it i gotta get some!
            i am going to try using it today on a dry car, last time i tried on a wet car and maybe thats why the product didn't work as well...
            ill update my results tom.
            www.JEEPGARAGE.org
            • #36
              Re: Body Solvent
              I use it either during or after the wash.
              I let it dwell while I wash the wheels, tires, and wells.
              Its not something you can really wipe off, you have to rinse it off with water and usually follow with a soapy water agitation.
              Originally posted by Bill Davidson View Post
              Yes for sure, it certainly helps, but then you have to let it dry again. Body solvent is oily, oil floats on top of water. What you are wanting to do is saturate the contaminate right through to the paint level. If you have to soak through a 1/4 inch of bug guts vs. a trace, more solvent and more dwell time will be needed. I guess the method you use is going to depend on how much time you have.
              Lets say you come in off the highway you might want to pull into a car wash and spray the front of the vehicle to get rid of most of the bugs. By the time you get home the vehicle will be dry enough for Body Solvent.
              The same thing can be said for tar. You might want to spray, let dwell, wipe most of it off, then spray once again and remove the remainder. Usually tar smears a little with the first wipe.
              Thanks for the tips.
              • #37
                Re: Body Solvent
                Ordered my first gallon from ADS on Tuesday (with a whole lot of other goodies )
                I'm assuming an area treated with BS doesn't need a re-application of sealant?
                Usually I pull out the clay bar for bugs / tar / sap. This looks to be a better solution for regular use.
                • #38
                  Re: Body Solvent
                  It does.
                  • #39
                    Re: Body Solvent
                    Yes I guess that makes sense.
                    So for the people that use BS (almost) every time to pre-treat certain areas, you are re-"waxing" those spots too?
                    • #40
                      Re: Body Solvent
                      If you want to protect the area, yes. We don't have that many bugs stuck to the fronts of our cars out here in California, so the rare time that I will use body solvent on overly dirty cars, I re-wax the area. It could become a pain in the butt if you use it on a regular basis, but any bug remover will remove wax.
                      For a regular wash, try soaking the bugs with a soapy wet towel before washing, that way you won't have to re-wax, but if you are plan on claying and waxing anyways, what's the harm in using Body Solvent?
                      Remove swirls my friends.
                      • #41
                        Re: Body Solvent
                        The bugs around here have been a nightmare this year. Few months ago, run up north to buy some parts it sounded like pouring rain with the bugs hitting the car.
                        Once within a few miles from home I hit the first auto car wash (it was midnight, didn't feel like washing the car).
