APC+ Alternative
  • APC+ Alternative
    I bought my APC+ because ADS suggested that it would clean everything from interior to tires, wheels, etc. Yes it works but I don't like using it when I clean my tires and wheels. It just doesn't foam up at all. What are the other alternatives in the detailer line that's best to use for wheels and tires (that foam up)
    Thanks.
    Re: APC+ Alternative
    APC+ is made not to foam. Regular APC will foam. I have that and the high output foaming sprayers. I also have Simple Green and 2 of their spray bottles which have a foaming setting.
      Use wheel brightener 4:1 or 6:1 (I have both) on painted wheels... DO NOT use on polished, chrome, etc.
      Ivan Rajic - LUSTR Auto Detail
      Chicago, Illinois
      Recognized as One of the Top Nine Auto Detailers in the US by AutoWeek Magazine!!
        Just to chime in...a quick correction
        Meguiar's D140 Wheel Brightener is safe on: clear coated, factory painted and chrome wheels.
        It is not safe for: anodized, magnesium, or polished aluminum wheels.
          Thanks.
          Hey,
          Meguiar's APC+ is an awesome cleaner and one that I use regularly on tires etc for deep cleaning. It is has a low foam ratio so it can also be used in extractors. However, if you want foaming for a more visual cue, then use the regular APC with a foam head sprayer as Roushstage2 said above.
            Thanks.
            APC or Super Degreaser
            AeroCleanse, LLC
            www.aerocleanse.com
              Just to chime in...
              Be careful with using the Super Degreaser around paint. The paint around the area should be sprayed with water before spraying the Super Degreaser onto the tires/wheels. If the Super Degreaser gets accidentally sprayed and dries on the paint or the paint is hot/very warm and the Super Degreaser evaporates to a stronger concentration, paint staining can occur.
                Why was APC+ formulated not to foam? It seems that it doesn't help clean dirty wheels. You need to drench the object you're cleaning in order to do a good job.
                  It was formulated not to foam so it could be used in carpet extractors. I know when I use APC in my little green machine the dirty tank fills up fast with foam, but when using APC+ it doesn't. If you want foaming go with APC and a foaming sprayer.
                  Scott
                    Interesting....How does the APC+ compare to the Bissle stuff you get at Target for carpet cleaning? I have never even though of using it in my Little Green. Do you use the same amount too (up to that little line)?
                    Thanks,
                    Rasky
                    Sorry for the off topic post Marc
                    Rasky's Auto Detailing
                      I've only used the sample bottle of Bissell so I don't have much experience with that. I don't put the APC+ in the LGM but have it in separate spray bottles. 10:1, 4:1 and I think the other one is 32:1. I'll probably give it a try in the LGM this year. I don't see why it wouldn't work.
                      Scott
                        Thanks,
                        Rasky
                        hahaha! no worries man!
                          Right on. yeah I use a pretreater too. What are you using for an extractor cleaner then in the tank?
                            Plain water. Do you use the Bissell chemical and a pretreater too?
                            Scott
                              Now that I think about it I guess I do it the hard way. I'll spray the entire floor down with 32:1 then the spots with 10:1 or 4:1 depending how they look. Work the entire floor with a stiff brush and let it sit a bit. Then spray hot water from the LGM on and work with a brush again. Then extract, then hot water and extract again.
                              I don't do many interiors but I guess it would be easier to put the solution in the tank. Then dump out the extra and fill with plain water for the rinse. Maybe?!?!
                              Scott
