Tell me about #66.......
  • Tell me about #66.......
    I have a high demand for "wash and waxes" and I'm using the rotary a lot more now. Something inside me still wants to remove defects though.....not just cover them up.
    Will #66 remove light defects with the rotary?
    How long will it protect?
    I appreciate your experience and comments!
    Justin
    www.clean4udetailing.com
    Re: Tell me about #66.......
    hey justine
    Haven't posted much the last 4 or 5 months but do want to tell you that you do great work!
    Anyways what I do know about M66 is that it is the most aggressive cleaner/waxes meguiars has.
    M66 has swirl filling properties on highly sensitive paint.
    It's like a bandaid if you will! it covers scratches and will come back after a few washes though.
    scratchX by hand uses diminishing abrasives and chemical cleaners is less aggressive version of M66.
    Also colorX & M66 when applied by machine can remove light swirls and scratches, and also helps micromarring.
    Some of my notes about meguiars products I have, Hope that answered your question.
      I feal the same way so i go over the car with 21. The paint will just look better longer .
        I'm not sure about with a rotary, but with a PC #66 removes a pretty decent amount of defects. Obviously don't expect it to remove as much as #80, but it still does a pretty good job of removing them, not just covering them (although it does cover some too).
        Lydia's Mobile Detailing
        2007 Honda ST1300 - Silver
          #66 is a very good cleaner wax. It does have some capabilities to remove light scratches and swirls. Lately it has become one of my favorite products. After I put a layer of #66 on, I use #21 and the pop I get is all worth it. Good wax to stand on its own also.
            It will hardly reduce swirls because it is a cleaner wax. It will fill in the scratches. The longevity will depend on what elements is the car facing on a daily basis. It will more likely bring more gloss to the finish.
              CAShine have you ever had a chance to use it? Perhaps I just used it on soft paint, but when I used it on my sister's car, it actually did a pretty good job of removing fine swirls. Now it's certainly not as good as a dedicated polishing step, but IME it worked pretty well.
                As cleaner waxes go #66 is pretty potent stuff. If you have fine swirls and use it with a rotary it will certainly get rid of them. Obviously the "softer" the paint the more it will remove. But compared to something like Meguiar's consumer line Cleaner Wax, it's a night and day difference. It's also great on super sensitive paints because you can back waaaay down on the speed and use a finishing pad with beautiful results.
                  Adding to what Mike-in-orange had to say, the protection lasts a month or more. These are on daily driven, parked outside in the day, garaged at night vehicles. The vehicles are done monthly, so the layer of wax is constantly maintained. On a well prepared surface, I can't say enough about the results of 66. IMHO, it's the perfect product to do your wash and waxes with.
                    I think #66 is a wonderful Product. I also think it is not talked about enough.
                      Ok guys. Thanks so much for all of this info!
                      All I'm looking for is about 4-6 weeks of durability. I do not want to have to top it though. That would defeat an all in one. I would just use a polish then wax. I've been using Malco's Aqua Wax on my customer's cars when I dry them. This really helps the protection of any lsp.
                      Will it stain trim?
                      This is important to know for me.
                      Thanks again!!!
                        It's ranked with the same "cut" as #80.
                          Originally posted by justin30513 View Post
                          Will it stain trim?
                          Yes. Most cleaner/waxes on the market will stain trim.
                            M80 is a cleaner/polish, that's a type of product
                            M66 is a cleaner/wax, that's a different type of product
                            All things being equal, i.e. same pad, same tool, same person, same paint, etc. in most cases M80 will tend to remove defects a tad better.
                              Originally posted by stang_krazy View Post
                              hey justine
                              Remember that any wax or paint protectant that's actually "working" is filling because if a wax is adding a "Layer" of protection on top of the paint, then by its very nature it's filling at some level.
                              It's also important to remember that Application Material and Application Process is a HUGE factor as to how aggressive or non-aggressive a product is, by this we mean using M66 by hand will be less aggressive than using M66 with a rotary buffer. Using M66 on a rotary buffer with a wool pad will remove more defects than using M66 on a rotary buffer with a foam polishing pad.
                              M66 is very versatile and is not only a great one-step product, it's also very popular in the detailing industry for exactly what you want to do.
                              Just be careful around trim or tape it off.
