Quik Clean or Quik Wax ?
  • Quik Clean or Quik Wax ?
    Hi All:
    (on my boat)
    Not sure which product to use. Both seem to indicate that they will produce a glossy shine, and both seem to indicate that they will do "some" cleaning of the surface. Obviously, the Quik wax will also add wax, but on a previously waxed surface, does this matter that much ?
    Will the Quik Clean remove any of the existing wax ?
    If I was to "stay on top" of the cleaning, say, every other day or so, which product would be best
    Thanks for any help !
    Jeff
    Re: Quik Clean or Quik Wax ?
    They are similar to the car line Quick Detailer and Quick Wax.
    That means that the Quick Clean will clean off light/fresh dirt. But leave no protection behind.
    The Quick wax will want used on a clean surface. The description for it even says to use after washing.
    You could look at the Flagship ultimate Detailer, which would remove light dirt, and leave a little protection. Not as much as the Quick Wax, but some.
    So if you washed your boat after use, you would dry while using the Quick wax.
