Grit Guard
  • Grit Guard
    I bought a Grit Guard off eBay and a 5-gallon bucket from pep boys. The grit guard doesn't look like it goes all the to the bottom of the bucket and if it does only the edges touch very lightly. Has anyone else used the Pep Boys bucket? Or is the how it is supposed to fit?
    Re: Grit Guard
    I believe the grit guard site actually tells you who's bucket the grit guard will fit,
    Give it a look
      Re: Grit Guard
      Return your Pep Boys buckets and buy a pair from Home Depot. Not only will you save $2 per bucket, the Grit Guards will fit the Homer buckets perfectly
        Re: Grit Guard
        Thats fine that it doesn't go all the way to the bottom. Some people actually stack two Grit Guards to get the wash mitt even further away from the bottom of the bucket. So you're getting the benefit without the extra cost.
        Colin
          Re: Grit Guard
          I use my Grit Guard with Pep Boys buckets, no problem.
          2011 Ford Mustang GT Cali Special
          2012 Kia Sorento EX
            Re: Grit Guard
            Thanks for the quick replies. Just to give everyone an idea it is close to the bottom, I measured the top of the grit guard from the bottom by looking at the outside of the bucket and it is about 3.5" away
              Re: Grit Guard
              Yes, some buckets taper toward the bottom.
                Re: Grit Guard
                The grit guard seems to fit the Home Depot bucket almost perfectly. You can get a snap on lid too. The only downside is that it is orange. I like a more translucent bucket so you can judge water level.
                I just tried stacking two grit guards in the rinse bucket and use no grit guard in the soap bucket as demo'ed by Mike Phillips. I can get by with 2 gallons of mixed soap using a two bucket method and have plenty of clean soap to spare. If I use a grit guard, it will block access to 1 gallon of soap or water and I do not really see a need for a grit guard in the soap bucket if using the two bucket system.
                Al
                ~ Providing biased opinions
                  Re: Grit Guard
                  The grit guards also fit the buckets from Advance Auto parts perfectly.
                    Re: Grit Guard
                    They must have changed buckets or, I was sold some old ones at Advance. My NEW Grit Guards do not fit. The buckets taper.
                    Rob A.
                    '07 Kia Optima (Gold)
                      Re: Grit Guard
                      I use two different colored buckets..one from HD and one I just had (white)...that way I don't get too confused on which is rinse and which is wash..it gets confusing after a few rounds
