Re: Hot Rims® All Wheel Cleaner
Guys verdict is in:
I only have coated rims and both vehicles!! I took metal polish with white rag and NO black stuff came off on the rag!! So I tried and little bit on my in bed tool box and black stuff came off on the rag. So now I know how to tell the difference. Thanks for explaining this to me!!
So there is no need to do the rims with metal polish? Just treat it like paint like Roushstage2 said? Would it be too much to do the DC 1 2 3 steps? Or just clean them and apply wax?
No. You should treat it like paint at that point.
Originally posted by Mike Phillips View PostMake sure your polish is non-abrasive, that is it won't scratch or you could scratch your wheels, coated or uncoated.
Anyway, take a light polish/paint cleaner, a product like ScratchX or Deep Crystal Paint Cleaner works well because both products are very white in color, thus they show aluminum real easy when rubbed against an uncoated aluminum wheel and this will tell you they are uncoated, that is the cloth will turn dark gray and blackish.
If your wheels are coated or anodized aluminum, the as long as the surface is clean of loose dirt and road grime, rubbing a paint cleaner or a metal polish against the surface shouldn't pull any color, that is your cloth and chemical will stay the same color they started.
Originally posted by sneek View PostNice!! What colour / engine? is your Accord?
Originally posted by Speedway View PostI was at my local target and picked up some Hot Rims® All Wheel Cleaner on clearance for $1.48 I was reading the bottle and it said it is safe for all factory coated rims. I have a 08 Accord with coated rims and a 98 Chevy with aluminum rims but I don't think there are coated dose anyone know if it is OK to use these rims. Or are my rims on the Chevy coated?
Originally posted by Speedway View PostFound some polish will try when I get home. Is it pointless to use metal polish on coated wheels? (ie, Wifes car)
I will pick some up and let you guys know what I find!! Thanks
I would use Multi-Piece wheel cleaner or just soap and water until you know for sure APC has a tendency to stain uncoated rims. You can use any polish to test for clear coat using the same process roushstage2 mentioned.
Do you have any metal polishes? I'm not sure if a paint cleaner would turn it black...
Is there any other way to see if they are uncoated. I look and my wifes car and I know that her wheels are coated and I compare them to mine and they are not as glossy as hers. I also can take my finger nail and scratch it if you will but then I can remove the mark by wiping it off with a cloth and watery soap.
Originally posted by 08 Corolla View PostThe Hot Rims AWC is safe for clearcoated rims and i'm sure it's also safe for aluminum ones since it's an ALL WHEEL CLEANER.
As far as washing uncoated aluminum wheels, I would stick specifically with an aluminum cleaner or just use soap and water.
no I do not have any NXT meatal polish. I should just stick to using APC+ on the rims and be safe. This would be safe right? Diluted of course.
