working with marine fiberglass
  • working with marine fiberglass
    I've finally had it with "shade tree" boat detailers who do lousy work.
    I understand Meguiars 1-2-3 step process for conditioning the gel coat, sealing the gel coat with a polish, and finally protecting the polish barrier with "sacrificial wax".
    Here's my question: what type of buffer pads do I use during the 1-2-3 step process including application and removal (these should be different pads right?)?
    Any help would be greatly appreciated.
    Re: working with marine fiberglass
    What kind of machine will you be using?
    How bad is the surface/damage that you will be working on?
      Your not going to want to use the Deep Crystal System on a fiberglass boat.
        you will def need to use the marine line. fiberglass is a lot tougher than CC
        www.JEEPGARAGE.org
          Thanks for the replies! I'm using three different machines, 1) a 10" orbital buffer, 2) a Milwaukee Tools variable-speed drill-motor (buffer) and 3) a 4" angle grinder (buffer).
          I know there are different uses for wool pads vs. soft pads.
          Yesterday I heard from the mechanic who had worked on the outdrives that the "detail" man had used sandpaper on the gel coat! This for only a light level of oxidation!
