Dazed and Confused
  • Dazed and Confused
    Hi there! Just wondering if I can get some help. I have a Chevy S-10 Crew cab P/U Truck, almost 5 yrs old, paint is prety good, not as new, but the usual 5 year deterioration. Well kept using Maguiar's No 7 and No 26.
    Through the years I have used a truck cover to protect the paint finish from the sun and other weather elements when I am at work, as my office is nearby a power plant, so sulfur dioxide stains are very rare in the paint finish. Also the truck cover protects it from bird droppings, which basically has been very rare.
    Recently I washed my truck and used the No 7 and No 26 products and later that week, there were some bird droppings in the hood of my truck, to be more specific 12 of them marks. This basically happened on a Thrusday, and the next Staurday I washed my truck using Meguiar's car wash and low and behold, the droppings were removed but I still have twelve stains in my hood, about two to three inches in diameter.
    I tried to use number 7 and then tried no 26, but the stains were still there. Also tried to use Scratch X, but no luck as well.
    Any Suggestions as of how to remove those stains? I have not seen anything like this before in more than 30 years detailing cars.
    Re: Dazed and Confused
    when using scratch-x did you use plenty of passion?
    hope that helps.
      The reason #7 didn't work is because it is a polish that contains no abbrasives.
      ScratchX can be very effective if you put the effort into it.
      Try ScratchX again. If that doesn't work, pick up a bottle of Fine Cut Cleaner (#2?). Fine cut is more abbrasive, but can also be used by hand. I'm a big fan of it.
      Can you post pictures so we can analyze the damage?
      Chris
      Dasher Detailing Services
        Thanks for the tip!! I will try to take some pics today and post them for your review.
          hope that helps.
          When using Scratch-X did not use pasion, thanks for the advise.
            Besides using passion with the scratchx don't be upset if it takes more than 1 pass to see some results.
              besides the passion and amount of passes, don't be upset if it takes an hour to say do one side or the hood by itself.
                Pic are posted, two of them. Use this search words for them: Pick Up Truck Hood bird droppings. Hope they are clear enough to see the stains.
                  I posted the pics for others to see:
                  I'm having trouble viewing the spot. I can see a few hazy areas, but I'm not really sure. If these hazy areas are the problem, Fine Cut Cleaner should work well.
                  Chris
                    i tried searching to no luck.
                    i can't click those pics either to blow them up.
                      Hey Guys, the few hazy areas are the spots. Today I used scratchX and they were removed. Excellent suggestion!!!! Did do a lot of passion and dedication with it.
                      Again Thanks!
