using multiple products
  • using multiple products
    hi can you use m#7 then m#26 and finish with nx 2.0 or is the first two enough
    thanks mark
    Re: using multiple products
    If you wanted to use those three products in combination, I would recommend #7 first, then NXT, and finally #26.
    NXT is fully synethic so it should be applied prior to M26 if you follow common logic. Sealant before Carnuaba.
    I would do one half of your hood with M7, NXT, M26 and the other half with just M7, M26 and compare them. See if you see a difference in how they look or how they hold up, then go form there.
      Re: useing multible products
      Using M07 and then m26 would be a great choice. Since M07 is a pure polish with a good wax like M26. Or using the M07 with the NXT.2, which is what I use on my personal vehicles. is also a great choice. Using all three is up to personal choice. I personallly think you would not gain anything using the two waxes on top of one another.
      Sleepy
      Love the Classics!
        2 thin coats of wax is recomended, so you can certainly combine them to get that.
        Perhaps your best bet would be to do a panel in each combination, and see which you like best.
