A tip for using the forum search engine
  • A tip for using the forum search engine
    Some tips for using our forum search engine
    If you're looking for a thread on a specific topic and you think you might know a keyword used in the subject line, then type your key word or words into the space for keywords and then right below it there's a drop down box where you can select
    Search Titles Only
    Select this option. This will only pull up threads with your key word in the subject line. The other option pulls up all threads with the keyword or keywords in all the the messages, which could be a zillion threads.
    Here's an example,
    Click on the advanced search engine like this,
    Here's the direct link to the Advanced Search Engine
    Now type in the word hatred and select "Search Titles Only" and then hit the Search Now button or your ENTER key.
    And you'll pull up all the threads on this forum with the word hatred in the subject line which is 1
    My Hatred of Clear Coats
    But this shows you another way to search for specific topics if you know a word that might be in the subject line, it will reduce the number of results you pull up and in some cases reduce the amount of time you search for a topic.
    You can also modify this by searching for a specific word in a Subject Line is a specific forum group. To do this, simply do all of the things already listed above but also use your Ctrl key on your keyboard and hold this key down and then using your mouse click on the groups you want to search.
    Simple Simon!
