Meguiar's at Mobile Tech Expo 2012
  • Meguiar's at Mobile Tech Expo 2012
    Jason Rose will be conducting a series of seminars at Mobile Tech Expo in Kissimmee, FL on January 19th - 22nd, 2012. If you're a professional detailer, or just interested in advancing your skill set, these seminars are a great way to enhance your capabilities.
    Jason's topics will include:
    DA Microfiber Correction System - Guaranteed swirl-free paint defect
    removal with a D.A. polisher...at its best. Does your rotary polishing have
    you going in circles? Or does your lack of knowledge and experience with
    rotary polishing prevent you from getting defects removed without fear of further
    damage? Want to make more money machine polishing paint? Learn
    how easy it is to get fast customer pleasing results on paint. Perhaps you have
    tried this new revolutionary polishing system, and want to learn more? This
    seminar explains what this remarkable new approach is, advantages over
    rotary polishing, and how you can experience lower labor/material costs with
    more profit per car. Bonus - learn about the tremendous versatility of this
    exciting new system and its many uses beyond just polishing paint.
    The Power of 3000 Grit! - That's right, you read it correctly...the POWER of
    3000 grit?! Isn't 3000 grit sand paper considered mellow? The Meguiar's
    Unigrit 3000 Finishing Disc is different. This amazing new approach represents
    the future of removing severe paint defects.. You can continue to hammer
    them out with more aggressive methods that are risky or too invasive on
    paint (like rotary with a heavy cut compound and wool pad)...or...you can
    have a new approach with complete control, and lower risk, removing severe
    defects fast & easy while leaving more paint on the car. This new approach
    makes it possible to go after severe defects with an all DA process or less
    aggressive rotary steps. Come and check out this seminar to see if this new
    approach will fit into your paint defect removal processes.
    Headlight Restoration for Big-Time Additional Revenue - Headlight
    restoration is an easy up-sell with very little additional time and effort. It's the
    fastest growing new revenue segment for detailers right now. Learn this easy
    to use system. The process will be explained start to finish. You will walk
    out of this seminar knowing what the steps are...and how much more additional
    money you could be making in your business.
    Paint Defect Removal Rotary Polishing Technique - Rotary polishing
    techniques are explained and analyzed. What are the 5 rotary machine
    polishing variables? How does each variable contribute to the over all
    polishing result? Are swirls a challenge for you? Having trouble adjusting
    between hard and soft paint? From a global perspective, how do techniques
    differ around the world? Which technique should you be using?
    This seminar is primarily targeted towards experienced rotary users that
    want more understanding and versatility with a desired technique.
    However, for someone new to rotary polishing, this seminar will help to
    understand concepts and variables before learning which technique is
    best for you to master.
    More information on times and locations are available at the Mobile Tech Expo website.
    Re: Meguiar's at Mobile Tech Expo 2012
    Great topics.
    I wished I could travel to Florida next week.
