Just curious, is/are there any problem(s) anyone has had with this forum while using IE10? The reason I ask is the 'enter' key no longer wants to work here on MOL. I, at first, thought my keyboard had gone south, but I've had no problems with other forums. Thanx...Bill
Compatibility with IE10
Re: Compatibility with IE10
Originally posted by BillE View PostJust curious, is/are there any problem(s) anyone has had with this forum while using IE10? The reason I ask is the 'enter' key no longer wants to work here on MOL. I, at first, thought my keyboard had gone south, but I've had no problems with other forums. Thanx...Bill
Now im used to getting flamed on this point and because I am a web designer developer as part of my work day I tend to get a little passionate about the subject - but just try one of the aforementioned you will be glad you did - also for the flamers Google ie market share and my point rests.( I just did an info graphic at work and ie is well below 40% even at conservative "we hate ie levels.").
Oh, I'm not going to start flaming-LOL. I wasn't planning on even upgrading to IE10...I missed that it was on the semi-monthly updates from MSFT. I did read a couple of articles (one from CNET) that really did laud the benefits of the 'new' IE. One nice thing is the built spell checker! Works a lot like "Office" (I can't spell worth poo). Back on topic, I have absolutely NO problem on any other site that requires 'my input.' I take on-line classes and (thank goodness) no problems. Thanx for chiming in...Bill
I can probably fix your issue. Check your editor options under your profile, unless you've fixed this already. I know it was 20 days ago with your last reply. I found out something a while back with the enter key not working.
Click on Forums> Click on Forum Actions > General Settings > Scroll down to Miscellaneous Options > Make sure Standard Editor is chosen, if not change it then choose Save at the bottom and try again.
I had changed mine to "Enhanced Interface - Full WYSIWYG Editing" and it would not use the enter key for nothing. Changed it back to "Standard Editor - Extra formatting controls" and it was back to normal.
Good luck.
