A suggestion of an existing one.
I have used the Meguiars softbuff pads exclusively for years. Aside from an early batch years ago with the known adhesive problems, I have never had a problem.
Having said that, when the pads do fail, it is always because the backing plate comes into contact with the foam during buffing. This causes a "cookie cutter" effect and eventually the BP chews the foam up. It also causes the foam to "spit" all over the paint, very annoying.
It seems that this could be solved by making the velcro contact patch about .5" larger in diameter. You would still have the centering hole for proper pad placement, but it would sure make my pads last longer.
Just a thought.
Just a thought.
