Meguiars S3BP 3 inch backing plate failed!
  • #16
    Re: Meguiars S3BP 3 inch backing plate failed!
    Call Customer Service and they will take care of you, they are the best in the business!
    • #17
      I'm not too upset about it. This is the only Meguiar's product that has ever failed me. It would be more beneficial for Meguiar's to look into why these are failing. Doesn't help that they are made in China.
      • #18
        I agree with made in china. I just don't get why we can't bring these companies home and finally have some quality in everything we buy. Stupid question but were u exceding the max rpm on the bp? It says on the back in that pic guz posted that 12,000 rpm max. I'm sure u guys used them right, but just an added thought.
        • #19
          I was certainly using mine below that speed. It seems more a screw seating problem than a direct speed issue. I was constantly tightening the backing plate to the screw until I just got sick of it, glued it and haven't had the problem again.
          IMO when the screw isn't 100% tight (and you aren't always immediately aware of it when it's occurring while you're buffing) the usual downward pressure is now not directly over the centre of the backing plate and this puts too much pressure on that point. Result: screw pulls out of the backing pad.
          Keep in mind also that the smaller the backing plate the higher the level of force a machine is throwing through a smaller surface area. Coupled with the particular movement of a DA machine....
          • #20
            DA's are rated at OPM's (oscillations per minute). Rotarys are RPM's. On my PC I was using it around speed 3-4 with a 3" microfiber cutting disk for spot corrections when I used it.
            • #21
              LOL... I'd like to see any DA that could get close to 12,000 rpm
              • #22
                Mine will do 12000 OPM top speed, but I'd want to have a good grip if was 12000 RPM.
                • #23
                  • #24
                    • #25
                      Originally posted by RPPM View Post
                      Get a Lake Country 2 & 7/8ths backing plate. It is the same size as the SB3. I have had the same issue with 2 of the SB3's so i won't use them anymore. I even used Locktight on the 2nd. Beware, even with that, it is just a matter of time until it fails.
                      Is this the one you're talking about??
                      • #26
                        It's this one.
                        • #27
                          Sorry we missed this thread early on, and even more sorry that you've had this issue with the S3BP, KidDetailer. Hopefully by now you've contacted our Customer Care Center and they are replacing this for you. If not, I'm moving this to the Customer Service Hotline section of MOL as that will immediately alert Brian Hann of the issue.
                          • #28
                            KidDetailer,
                            Just sent you a PM.
                            Brian Hann
                            Manager - Meguiar's Solutions Hub
                            Irvine, California
                            bhann@meguiars.com
                            (800) 854-8073 *3870
                            • #29
                              Received PM, and responded.
                              Appreciate the customer support.
                              • #30
                                I have received a new S3BP backing plate from customer support. I'll try the backing plate again...with out the washer this time. I hope the plate doesn't fly off.
