The back of my pad ripped about a half inch from the velcro area. Only the second time I used it.The rip is only about 1/5 through the pad. Is it still usable in a jam or will it rip all the way through.
Had an 8006 pad rip
Re: Had an 8006 pad rip
Are you using the PC's backing plate? Do you have the Meguiars backing plate?
Make sure the backing plate is centered in the pads backing, there should be a small portion of the pads backing showing all the way around the backing plate, if this is not the case the pad could. Also you don't want to much downward pressure, this to can cause it to tear as the backing palate 'digs' into the foam, even more so if your backing plate is too big.
Hope this helps!Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by kboxer View PostThe back of my pad ripped about a half inch from the velcro area. Only the second time I used it.The rip is only about 1/5 through the pad. Is it still usable in a jam or will it rip all the way through.
It sounds like you are using either: Too large of backing plate, using too much downward pressure when buffing or using too high of speed (do not go above speed 5 on the G100/PC).
Originally posted by kboxer View PostCould be too much downward pressure. I used the backing plate that came with it. Seems to work ok.
That is what it sounds like; too much pressure causes the pad to mushroom excessively. If really excessive pressure is applied the action of the buffer will cause the pad to tear.
Here is an excellent thread where Mike explains how much pressure to use when using the G100.
I hope this helps!
Originally posted by kboxer View Post...I used the backing plate that came with it. Seems to work ok.
If it’s a Porter-Cable plate that’s probably your problem right there. That plate overhangs the pads’ loop backing and tears up the foam.
PC.
