We are proud to announce the 1st of several new Quik Tip Videos for 2011 !
After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
Please keep in mind that this video, and the others in the series, are not designed to be definitive how to guides but rather, as the name implies, Quik Tips that address the most common questions and mistakes associated with each topic.
Adding wax protection to your vehicle is normally a straight forward process using Meguiar's Waxes.
However, with the introduction of our new Meguiar's Ultimate Liquid Wax, we've made this process even easier.
Meguiar's Ultimate Liquid Wax is the result of all new chemistry which contains cross linking synthetic polymers as well as Meguiar's Hydrophobic Polymer Technology. This combination not only gives you incredible water beading, but also provides maximum protection and durability. It truly is our most advanced wax ever!
Meguiar's Ultimate Liquid Wax also utilizes Meguiar's Thin Film Technology which allows for an even smoother application and faster wipe off, even in direct sunlight.
In addition, Ultimate Liquid Wax's new synthetic formula won’t turn plastic trim white like most traditional waxes.
Before waxing, remember to wash and dry your vehicle thoroughly, and make sure it’s free from any defects or bonded contaminants. If not, you'll need to use our Smooth Surface Clay Kit or one of our paint cleaners like Meguiar's Ultimate Compound to properly prep the surface before applying Meguiar's Ultimate Liquid Wax.
Whether you're working by hand or a Dual Action Polisher, Meguiar's Ultimate Liquid Wax with Meguiar's Thin Film Technology allows you to be flexible on the application and removal. This means if you prefer to apply it to the entire car before removing it, you'll have no problem.
However, our new technology also allows for a wipe on / wipe off type of application. Apply Meguiar's Ultimate Liquid Wax to a small section at a time, wait 3-5 minutes, then easily remove it with the included Supreme Shine Microfiber Towel.
With either method you choose, our testing confirms, you'll be getting maximum protection and water beading.
To extend the life of Meguiar's Ultimate Liquid Wax, always use a wash designed specifically for car finishes like Meguiar's Ultimate Wash N Wax on a regular basis.
_________________
