Meguiar's Quik Tips Video Series - Washing
After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
Please keep in mind that this video, and the others in the series, are not designed to be definitive how to guides but rather, as the name implies, Quik Tips that address the most common questions and mistakes associated with each topic.
Washing is a vital step in keeping your car looking it's best. Unfortunately, when using the wrong product or technique you can easily remove your wax protection or possibly create swirls. So when washing your car, never use household detergents as they can strip wax protection and promote oxidation ...always use a premium carwash like Meguiar's Ultimate Wash & Wax, Gold Class Car Wash Shampoo & Conditioner, NXT Generation Car Wash, or Deep Crystal Car Wash. Before washing, make sure your car is in the shade and the surface is cool to the touch.
Begin by mixing your wash solution in a clean bucket using the proper dilution, then fill a 2nd clean bucket with plain water.
Before washing, rinse the entire vehicle to remove any loose debris.
Using our Microfiber Wash Mitt, begin washing and rinsing one section at a time, working from the top down.
When your mitt becomes dirty, simply rinse it out in the bucket of plain water before retrieving fresh suds.
Once you've washed and rinsed the entire car...it's time for a final rinse using a flow of water rather than a spray. This is done by removing the nozzle and letting the water flow across all surfaces which will allow the water to run off and leaving you less water to dry. This is what a traditional final rinse leaves - plenty of water beading on the surface means a lot of water to dry off.
After taking the nozzle off the hose and simply flowing water over the surface the majority of beads are sheeted away and there is less water to dry.
Dry any remaining water using Meguiar's Water Magnet waffle weave microfiber drying towel...and don't forget the door jambs!
Remember….washing weekly using the right products and technique will ensure your car is free of contaminants and looks it best...all the time!
