How to do a Test Spot
  • How to do a Test Spot
    TEST SPOT
    Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
    Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
    Make sense?
    It should look like this,
    And if you're having any problems, the post back here after the test section and we'll help you tweak your technique to insure you get it right.
    Re: How to do a Test Spot
    sounds good to me
    smith
    braindumps oracle ccnp comptia a+ cisco certification
