  • Recommended Products - G100a Dual Action Polisher
    Recommended Products for Removing Below Surface Paint Defects using the G100
    Quik Clay System
    G-100a
    1 each W-7006 SOFTBUFF™ Cutting Pad (For use with the Gold Class Bonnets)
    2 each W-8006 Soft Buff® Foam Polishing Pads (For use applying cleaner/polishes)
    1 each W-9006 SOFTBUFF™ Finishing Pad (For use applying NXT Tech Wax)
    #83 Dual Action Cleaner Polish
    #80 Speed Glaze
    Meguiar's NXT Generation Tech Wax
    Supreme Shine Microfiber
    X4003 Gold Class Clear Coat Safe Microfiber Bonnets 2-Pack
    Quik Clay System
    G-100a
    #80 Speed Glaze
    Picture coming soon
    Hey Mike, I have the wax, DA, pads are on the way, have the clay system, microfiber, and Show Car Glaze o7, along with DC#2. I understand the DC #2 is not recomended for use with the G100. Is the 07 close to the #83 or #80? If so which one so I can order the other.
    TIA
      Originally posted by RRaider
      I understand the DC #2 is not recommended for use with the G100.
      The Deep Crystal Polish is a pure polish, in Meguiar's terminology this means it contains no ingredients with the intended purpose of abrading the surface, in other words it is completely non-abrasive and it's primary purpose is to create gloss, clarity, richness of color.
      It is perfectly fine to use with a dual action polisher, it would be the wrong product if your goal is to remove paint, or in other words, if your goal is to remove below surface defects because it's non-abrasive. If your goal is to remove below surface defects then we would recommend a cleaner/polish which is a polish that does contain ingredients with the intended purpose of abrading the surface.
      TIA
      The #7 is close or similar to the Deep Crystal Polish, that is it's a pure polish and completely non-abrasive.
      You need to read good old thread 2409 and focus on the section on polishes.
      Hope this helps...
        LOL, Mike, it's pretty sad when you know thread numbers.
          how does the step 1 paint cleaner compair with the other paint cleaners while using the G100, ive only used step 1 by hand.
            step 1 is very mild even when using the g100.. i would say that it is one of the least aggresive products out there
            however step 1 is good enough to remove paint transfer
            Patrick Yu
            2003 Honda Accord
            2008 Honda Accord EX-L V6
              that should be good enough for me then. my cars really dont have any flaws below surface that i can see, However im sure even though i maintain the paint very well there are still contaminants below surface that i can not see or feel. ive just used the step 1 each time before i waxed with nxt.
              heres a question, i use step 1 before i wax with liquid nxt, i follow the 5 step cycle religously. Now if i was reading it correctly before waxing its best to clay then use the cleaner?
              if the cleaner removes below surface imperfections, then it must also remove above contaminants as well, is that right? Or is it still really best to use clay, and the cleaner. Is there a time when you should just clay before waxing?
                ya if you need to clay then wash -> clay -> DC1-> DC2 (you didnt mention that you used a polish)-> NXT x2
                i dont think that just because you clay that you should skip the paint cleaner
                Patrick Yu
                2003 Honda Accord
                  well i was told by a meguiars customer rep last year that if i used step 1 and i used nxt wax that i could could skip the polish step, because the nxt wax was like a polish and a wax combined. now that was the 1st that ive heard of that, it doesnt say that on the bottle of the wax.
                  Either way i dont mind polishing, i was just told that i could skip that step.
                    lol theres a very very high chance that im wrong about the polish especially because you got advise from a megs rep so don't worrie about anything i said !
                    Patrick Yu
                    2003 Honda Accord
                      Re: Recommended Products - G100a Dual Action Polisher
                      an update of this thread would be great :]...
                      Ganesa,
                      Toyota Vios '05
                        Have you looked here?
                        Product, Pad and Speed settings for the Porter Cable Dual Action Polisher
                        Any other questions just ask.
                        Andy M.
                        Andy M. Moderator
                          wow, thank you for the link, I haven't read that thread yet...
                          big thanks again...
                          Ganesa,
                          Toyota Vios '05
                            Hi,
                            I use a G110 dual action. Prior to getting the DA, i was hand waxing my car using the NXT tech wax.
                            Is the tech wax still good to use with the DA ? I see that the finishing foam pad is suggested for using with the NXT Tech Wax. Apart from finishing off with a cotton terry, can I also use a separate finishing pad to clean it off ?
                            Thanks,
                            Terence
                              To remove a wax, you can either do it by hand, or with a cutting pad under a bonnet, usually a MF bonnet.
