Switching from 3M to Meguiar's - Rotary Buffer Questions?
  • Switching from 3M to Meguiar's - Rotary Buffer Questions?
    Hi there, well its me again guys, look i been using 3M products and they work good, i just use the Perfect-It II Rubbing compund and the swirl remover, but now i am interest on using Meguiar's and i found Fine Cut , Medium Cut and Heavy cut cleaners, wich i dont know why i think are similar as Dual action cleaner/polish, compund power cleaner, and diamond cut compund.
    The questions is what is the difference between them, i mean i know fine is light compound and heavy is agresive as dual action is light compound and diamond is the agresive one, but why there are like 2 ligth compounds and 2 agresives, is that because of different paints? like the ones of th ebody shops that sometimes are harder cuz of too much harnes and cheap paint, and that the stock ones are soft? Or is just preference or what would be a difference?
    Im sure a lot of you guys have used these products would you share with me some of your experience with them? plus comments.
    Sometimes you have to work on the Sun because theres no shade, also many compounds dry too fast cuz of the hot surface and evaporate leaving all sticky the compound on the paint, i dont know if this happens with these compounds. Also do they hide swirl marks? like i like to wash the car with a sponge after compund and polish just with water to remove all the dust left by compunding and polishing, and then after that i glaze it and protect it with a pure wax or polymer.(depending on the color) I been detailing for 2 years started with a rotary buffer burning some paints :P but well i have worked on 2 detail shops and a mobile detail, and i got some experience from there, also by doing some side jobs. I dotn burn paint anymore
    Welcome to MOL. check out this thread, http://meguiarsonline.com/forums/sho...+and+compounds
      Thanks, and i have also other question, after i compound should i use swir remover #9, swirl free polish #82 or speed glaze #80?
      And well by the number 9 and 82 i understand they remove the swirl marks left by compounding but by the speed glaze is it hides or is also a polish?, and also if its a polish(swirl remover) wich one is more agresive and wich one is less?
      I got confuse by reading a lot and now im like in shock, sorry
      Which one would you use?
        #80 is your best bet. It is very easy to use and leaves a great finish ready for you LSP. #82 is also decent, but I like the ease and finish left by #80 a little more. #9 can be a bit trickey and tends to smear on occassion.
          Thanks again for your fast response Travis, but #80 is not gonna hide some of the imperfections left by compounding?, i mean all glazes i know they hide, they dont remove swirl, thats what i am afraid of, and while #82 seems to remove them.
          Because youll see when i detail the car, after compound and polish i wash the car with a sponge and pure water, cleaning all the dust of the compound left, then i dry it and put a coat of wax or polymer.
          And if the glaze is gonna hide the swirls, when i wash it, the glaze will come down and leave that mirror finish full of swirls again.
          I know im crazy why should i wash teh car but, im used to. hehe i used to think the same at teh first time.
            #80 is not a filler heavy product. It will remove any hazing after your compounding step. A simple way of checking your work to be sure that you are actually removing the defects would be to use a 50/50 mix of water and alcohol to remove any fillers or oil left behind.
              Oh ok then i know what buy now Thanks you very much and im gonna try out these products
                Re: New at Meguiar's
                Originally posted by Solus
                Hi there, well its me again guys, look i been using 3M products and they work good, i just use the Perfect-It II Rubbing compound and the swirl remover, but now i am interest on using Meguiar's and i found Fine Cut , Medium Cut and Heavy cut cleaners, which i don't know why i think are similar as Dual action cleaner/polish, compound power cleaner, and diamond cut compound.
                Hi Solus,
                Welcome to Meguiar's Online!
                The questions is what is the difference between them, i mean i know fine is light compound and heavy is aggressive as dual action is light compound and diamond is the aggressive one, but why there are like 2 light compounds and 2 abrasives, is that because of different paints? like the ones of th body shops that sometimes are harder cuz of too much hardness and cheap paint, and that the stock ones are soft? Or is just preference or what would be a difference?
                The primary difference is they type of diminishing abrasive they use, at least that's the difference most people would notice when using them. All of these products, M01, M02, M04, M85, M84, M83, M82, M80, can be used on either clearcoated finishes, or non-clearcoated finishes. The 80's series are more modern technology based upon Meguiar's experience formulating products used at the OEM level. I would also like to add that the formula's for the Traditional Mirror Glaze Products, M02, M04, have also been updated when technology allows. I'm not sure about M01 Medium Cut Cleaner.
                Either way, both groups of products work well when used according to directions on the label and which one works best for you will be based upon your personal preferences.
                I'm sure a lot of you guys have used these products would you share with me some of your experience with them? plus comments.
                I think Travis has contributed a lot to this thread already, thank you Travis!
                Sometimes you have to work on the Sun because theres no shade, also many compounds dry too fast cuz of the hot surface and evaporate leaving all sticky the compound on the paint, i don't know if this happens with these compounds.
                There are no compounds, paint cleaners, cleaner/polishes or pure polishes manufactured by Meguiar's specifically formulated for use in direct sunlight on automotive paints. The sun, or more specifically, the heat created by sunlight will increase surface temperature of the finish and make any product more difficult to work with and affect the performance of the product dramatically. Meguiar's always recommends working on a cool surface in the shade. We understand that when doing mobile detailing work, this isn't always possible, one solution is to do what Joe of Superior Shine Mobil Auto Detailing does and that is to use a portable canopy when working in direct sunlight.
                You can check out Joe's most excellent before and after write-up on how he removed the swirls in the finish of the black BMW using Meguiar's compounds, polishes and waxes in the below thread. (If the below makeover doesn't knock your socks off, nothing will!)
                BMW 745il Extreme Make-Over
                Meguiar's compounds, paint cleaners and cleaner/polishes all use Meguiar's Diminishing Abrasive Technology. When used correctly, the diminishing abrasive technology Meguiar's has pioneered since 1901 and continues to improve today, will do two things,
                • 1. Remove the below surface defects, swirls, sanding marks, etchings, oxidation, etc.
                  2. Remove their own marks as they reduce in size and polish out
                like i like to wash the car with a sponge after compound and polish just with water to remove all the dust left by compounding and polishing, and then after that i glaze it and protect it with a pure wax or polymer.(depending on the color)
                I been detailing for 2 years started with a rotary buffer burning some paints :P but well i have worked on 2 detail shops and a mobile detail, and i got some experience from there, also by doing some side jobs. I don't burn paint anymore
                I would recommend reading the below two threads in the Hot Topics because they discuss in detail working what can and what cannot be done with a rotary buffer as far as creating a swirl free finish.
                Need HELP! - How to avoid holograms?
                How to avoid swirls and holograms?
                In the end, in order to guarantee a completely swirl free finish on a dark colored paint in bright lights, you're going to need to re-polish each panel either by hand or with a dual action polisher to insure any remaining minor swirls induced by the direct drive circular contact between your pad of choice on a rotary buffer and the paint are completely removed. That, or use a coating or two of wax to insure any remaining holograms or swirls are eliminated.
                Read the above two threads as there is a lot of good information in them that would not be efficient to try to re-post into this thread.
                Here is one example of a selection of products you can start out with when switching over to Meguiar's from 3M. This is not you're only option, but I'm trying to keep it simple with only a few products for you to experiment with.
                The M84 Compound Power Cleaner is an easy product to use with a lot of play time. It is formulated to be used with foam pads, not wool pads, so you can avoid using wool and thus avoid instilling wool fiber swirls.
                The M80 Speed Glaze is a light cleaner/polish that will remove fine swirls with our W-8006 polishing pad. The key to making this product remove any leftover swirls from the M84 Compound Power Cleaner is to make sure you buff the M84 completely so that you have broken all of the diminishing abrasives down completely. This is the trick to not leaving behind any deeper swirls with Meguiar's compounds. (Don't buff to a dry buff however).
                The M80 Speed Glaze is also easy to work with, offers a lot of play time, and easy to wipe off. You can then also use it with the dual action polisher to insure there are no remaining swirls. M80 Speed Glaze produces a very, very, clear and glossy finish, perfect for applying your LSP to.
                Again, the below recommendations are not the only products or method of tackling every car, but it is a system that will work on most cars that you will come across and 99.9% of the time, it will produce professional results you can be proud of and your customers will love you for and recommend you to their friends.
                It's also the system I used to remove the swirls on this clearcoated Corvette and restore a swirl-free, crystal clear finish.
                1999 Corvette - Remove Swirls and Scratches
                First Step Products and Process
                Rotary Buffer for removing serious below surface defects,
                  Mike thank you very much for all the information, i'm really impressed on how you took the time to explain me everything, and how infromative was all that, i saw the vette and also the BMW they look terrific, hehe but as always i got one more question, what is meant by product #66? i think superior shine used with a PC after DACP with red pad on the BMW.
                  Again Thanks, and i got the NXT paste Wax i really loved on my old black GTi .
                  Now im gonna buy#80, #84, #85 and #83 to use them with the foam pads, i just have yellow orange white and black pads, maybe i'll be able to buy the red one from Meguiar's :P.
                    Mike thank you very much for all the information, I'm really impressed on how you took the time to explain me everything, and how informative was all that, i saw the vette and also the BMW they look terrific, hehe but as always i got one more question, what is meant by product #66? i think superior shine used with a PC after DACP with red pad on the BMW.
                    M66 is a powerful one-step cleaner/wax that can be applied by hand, dual action polisher, orbital buffer or rotary buffer.
                    Quick Detailer
                    Now I'm gonna buy#80, #84, #85 and #83 to use them with the foam pads, i just have yellow orange white and black pads, maybe I'll be able to buy the red one from Meguiar's :P.
                    Just to note, the M85 is formulated for use with a wool pad.
                    M84 use with foam
                    M85 use with wool
                      Is #66 the same or almost the same as #80? Or what is the difference between them?, on the sticker it says the same grade of agresiveness
                        #66 is a simple one-step polish/wax. #80 is a polish that adds very minimal protection. The physical characteristics of the products are also very different. #80 is somewhat thicker, sometimes #66 can be very thin or watery. If you are doing a wash and wax #66 would be a good choice to provide a decent amount of protection. With #80 you will need to follow with an LSP.
                          Oh thank you Travis right at the time i was gonna buy it :P
                            Who has a coupon code that wanna share with me? im buying too much stuff lol this is addictive
                              FWIW, PI2 RC is said to have cancerous ingredients, and it dusts like crazy, toss it.
