The Challenge of Delicate Paint
This is a sticky topic.
  • The Challenge of Delicate Paint
    There has been plenty of talk on this, and other, detailing forums about how best to deal with difficult to correct or "hard" paint. But not much is discussed when the paint is so delicate that almost no matter how you touch it, it comes out looking somehow worse than before you started working on it.
    We've seen MOL members suddenly horrified to find that a product they've read about, and seen fantastic before/after images touting the virtues of, simply can't give the same sort of result on their car. Our Customer Care Center receives calls about how a given product seemingly damaged the paint on a customer's car. Often times this is actually due to a very aggressive applicator being used and not the product at all, but sometimes it is down to the product. In either case, a test spot would have helped prevent the problem.
    That does NOT mean the product is no good. It simply means that it isn't the best product match for that paint. We've seen plenty of comments from new users about how a wax or pure polish didn't remove their swirl marks, and more experienced users know that those products are simply not designed to correct that issue - they are just not aggressive enough. So no harm, no foul. But no progress either. Fine, just step up to a more aggressive product. But in this article we're talking about the exact opposite situation: those rare times when a product almost makes the paint look worse, even if it does remove the original defects.
    Fortunately, this situation is quite rare indeed, but when it does happen - and put yourself in the place of the car owner who experiences this - it's extremely annoying and frustrating. How are you supposed to deal with that? What product do you choose? How do you use it? A test spot can help determine that.
    Forum member Epileptic (known to his parents as Jay) has a 2008 Honda Civic sedan with extremely sensitive paint. We've seen him at Thursday Night Open Garage sessions, struggling to get a clear high gloss shine out on this car. Most processes he's tried end up hazing the paint and making it look dull. So, we invited him down to Meguiar's Garage so that we could experiment a bit and see what's what. Here's what we came up with.
    We lined up a collection of products, from mild cleaner waxes to powerful paint cleaners, and did a variety of test spots on the hood. Each product was used with a fresh foam applicator pad, by hand. We applied each product twice, using each as directed.
    As we suspected (knowing ahead of time that this paint is extremely delicate), Ultimate Compound did a good job of removing the defects in the paint but it left the finish looking very hazed. Stepping down to SwirlX we found a high level of defect removal, and with a lot less hazing. But still, the haze was there. Cleaner waxes such as our traditional Cleaner Wax, D151 Paint Reconditioning Cream, ColorX and M06 Professional Cleaner Wax only moderately reduced the swirl marks (which were quite heavy), in varying degrees depending on the strength of each. But at least they did not haze the finish. Of course, each of these had the added benefit of leaving wax protection at the same time, making them decent one step products. Overall, however, none were quite up to the task of fully removing defects. They were good and made a definite improvement, but we wanted more. You'll want more, too.
    As mentioned, Ultimate Compound left the paint looking hazy. Here's a close up of the UC treated section alongside the small area that remained untreated while under the masking tape. The reduction in swirls is better than what this looks like - the level of haze just makes the whole thing look, well, far from desirable.
    But here's another potential issue when working by hand on very delicate paint like on this Honda. It's very easy to develop pressure points under your fingertips, which translates into overly aggressive product application. We've even seen times where the user's finger marks could be seen in the paint following such an application. And using a terry cloth applicator on delicate paint just makes the situation even worse! Now, obviously the way Jay is putting pressure on this pad is not very good technique. But new users make mistakes like this. Still, even correct technique can create finger pressure points on very delicate paint.
    So how do you counter that problem? You need an applicator, and the foam applicator is really the safest bet. But if your finger pressure can translate into paint damage........ ugh! Well, we tried out a little adaptation of hand application and put to use a W8204 polishing pad with a S3HP hand pad. This gave us much more uniform pressure across the pad (and onto the paint) along with a more ergonomic applicator. In short, the pressure points were gone.
    Win - win? Well, it's an improvement in as much as the haze is both reduced and much more uniform in appearance. But there is still haze, even when using something as mild as SwirlX. This paint is that delicate! What's really important to keep in mind, however, is that the haze is actually quite minor and very uniform - meaning it is quite easy to correct with a very mild product.
    Those of you with a lot of experience correcting paint understand the concept of trading a severe defect (heavy swirls, maybe even sanding marks) for a less severe, more predictable defect (light holograms, a bit of D/A haze, etc). You also know that your new, more predictable defect is very easy to remove with a less aggressive follow up product. And the exact same concept applies here. To remove the haze from any of the more aggressive products, we simply followed up with a quality cleaner wax - ColorX. M06 Professional Cleaner Wax and M66 Quick Detailer also work very well for this step.
    Just how effective was ColorX at removing the haze? The image below shows the result. We took the Ultimate Compound test spot, as seen in the lower left, and split it in two, applying ColorX to half of it. And the difference is striking. But what's also great about this is that the application of ColorX was not a heavy elbow grease operation. Sure, we used a bit of pressure, but not like trying to remove heavy defects on "hard" paint. It was actually quite easy. And the results speak for themselves. You can clearly see the cross pattern created by the masking tape as we marked off the hood for the various products - and the level of swirls protected by the tape. But you can also see how badly hazed the UC treated area is, and this is what is so understandably upsetting to those who have experienced this. But look at the section right next to it; that was achieved with just a quick follow up of ColorX!
    This is the same area, closer up, taken from around the side of the car. So the lower portion is after treating with UC only, the upper section showing the follow up with ColorX. And if something as simple as ColorX can remove the heavy haze of an aggressive product like Ultimate Compound, the lighter haze of SwirlX is no match for it. And SwirlX did a great job of removing the swirls in the first place, as you'll see in a moment.
    Here's a close up shot of the difference between an area treated only with SwirlX, and the same area followed up with ColorX. It turns out that this particular paint was workable enough (or "soft" enough, as some would call it) that SwirlX was actually all the punch needed to remove the defects. Yes, it left a bit of haze, but less than UC, so the haze was a breeze to remove. Keep in mind the concept of using the least aggressive process to get the job done! Doing a test spot will tell you if you're being aggressive enough or not. When dealing with very delicate paint, you really want to go easy so as to avoid causing any more marring than necessary. With really delicate paint even a minor change in product or process can have a huge impact on the outcome.
    OK, so what have learned from all of this?
    Well, first of all............ wait for it.........DO A TEST SPOT!!! That is how you find out if you have really delicate (or really "hard", or really cooperative) paint in the first place. If you take anything away from this, let that be it. We can not stress this enough, especially for people who are new to paint correction. There is nothing worse than thinking a product/process is right for your paint just because you've seen so many great write ups using that product, only to discover it's not - after you've done the entire car! Paint systems differ, and the approach needed to work on them will differ accordingly. Usually the differences are fairly minor, but in some cases, like with extremely delicate paint, a very unique approach must be used to achieve the desired result.
    Secondly, you don't need to work terribly hard to correct defects in really delicate paint. If anything, a lighter touch is less invasive to the paint, creating less hazing and other problems. You may need a couple of easy passes with SwirlX, but that's actually less work than a really "hard" paint that needs two highly labor intensive applications of Ultimate Compound!
    Third, pay close attention to the type of defects you're initially trying to remove and compare them to what the paint looks like after your initial paint cleaning step. If the original problems are gone (water spots, fine scratches and swirls) but the paint looks really hazy and/or you can visually see your finger marks in the paint, odds are your paint is extremely delicate and you're being more aggressive with it than necessary.
    Fourth, if you really want to use something like NXT Tech Wax 2.0 or Gold Class Carnauba plus, you can certainly do so as a last step. But you will need to use the refining ability of a good cleaner wax first in order to remove the haze of the paint cleaner. Otherwise, these non cleaning waxes won't have the ability to remove the haze. They may hide it a bit, but probably not enough to satisfy you, even if you're only a bit picky about the appearance of your finish. In fact, it's the people who fail to do a test spot and just go straight to wax that end up annoyed and frustrated at the end of it all.
    Keep in mind that all of the above relates to hand application of products designed to remove defects. Using a tool like the G110v2 or other D/A changes the picture significantly. Still, you may well find that a very mild product is all that's needed to correct typical swirls, water spots, etc on these paints. The extra power of the tool coupled with the movement of the pad usually means that SwirlX one time takes care of the problem and even leaves less haze. Sometimes. It depends on the paint. We've even seen situations where ColorX alone (or M66 or D151) was sufficient all by itself when D/A applied. But do a test spot first to make sure.
    In fact, when everything was said and done, even though we still had that patchwork of test spots on the hood, we gave the whole car a once over with ColorX on a G110v2 with a W8207 Soft Buff 2.0 polishing pad. This is what we got:
    OK, so we've beaten the idea of a test spot into your heads (so we aren't using bold text for it any more), but hopefully we've also gotten you thinking about just how different various paint systems can be. And if you think this concept is only useful for those who are new to paint correction, think again. Look back to this thread we made last year - we spent a lot of time testing and eliminating products and processes before finally settling on one that worked. Imagine if we had just said "OK, this doesn't look too bad" and just jumped in with M105 on the D/A. We would have spent hours working on the car, been left with a mess, and forced to do the whole thing all over again! Any time you approach a make and model of car you've never worked on before, be prepared to adapt your process and product selection. Pay attention to how the paint is responding to your inputs. Stop and evaluate your progress - don't just jump in blindly and have at it. You never know how that paint is going to react until you do a ..............
    Re: The Challenge of Delicate Paint
    Great writeup Mike.
    Definitly will be helpful to those with this issue now and in the future.
      Great info, i had to work on a Subaru Legacy a while back, it was one of the softest paints i worked on, i had a hard time working with it because after getting excelent correction i would make scratches with my microfibers. it was a nightmare!
      then on the other side of the scale i have been hit with audi paint (really hard to correct on some cars) where 105 and megs cutting pad (g-220) wasn't making a dent in the swirls
        Do you guys think Meguiar's should sell a inexpensive test kit?
        Likely no matter how much you preach, most consumers are not going to spend $60 on 6 bottles of product, to figure out which $10 product they should be using.
        The write-up is fantastic, the logic is fantastic, but how do we get people doing this?
          Great thread Michael. Similar to Nelson's (Advance Detail) experience I was helping a recent Meguiars convert with his Subaru Impreza and the black paint on it was so "soft" that giving it a dirty look would cause hazing.
          Going through this process of trying different products on a small test spot allowed us to settle on the best products for the job and he was able to go away and buy the products that would work for his circumstances.
          He is also now fully aware of the process of that trading bad defects for lighter defects in a reducing process is acceptable, and that with patience a pleasing finish can be achieved.
          Bill - you raise a valid point, and there's no magic solution. I try as far as possible to meet up with new guys who post on our local forum to see if I can apply the "Each one, teach one" principle that Mike Phillips often referred to. Not a complete solution, but every little helps I guess.
            I think Meguiars should sell Michael Stoops and the others in a test kit. Open it up and let them do the "TEST SPOT" figuring. Then box them back up and put them on the shelf until the next vehicle!
            Great wrtie up Michael. VERY informative and descriptive write up.
            Don
              Very true, but far too many people automatically reach for the most aggressive product they can find thinking it's going to make the job go faster. Unfortunately, sometimes the opposite is true. But the people who really get into trouble are those who not only grab that aggressive product and use it in an aggressive manner, but do so without ever stopping to gauge their progress. They wait until everything is done, then pull the car out into the sunlight and they are horrified at the result.
              We certainly don't expect everyone to go out and buy a whole collection of products, but we would love for them to stop and think first about what they really want to accomplish, and how they really should go about getting there.
                Mike - Great write-up! Definitely provides guidance on working with soft paint but I hope it also shows people to NOT reach for the "20lb" sledgehammer when a 1lb rubber mallet will suffice.
                I like Bill Davidson's suggestion on a "test" kit but ultimately we need people to "buy-in" to performing test spots.
                Also got me thinking about using the Hand pad holder (S3HP) when applying polishes such as M07.
                Andy W.
                Ford - '91 Ranger
                  I like Don's idea. does Meguiar's employ any elves.
                  I agree Michael education is key. Test spots are essential, sometimes less is more.
                    Unfortunately, Mike Stoops is the opposite of an elf.
                    Going to have top look into one of those holders to try, though would be even better if it worked with the regular Hi-Tec applicators.
                      But we like to think "outside the box" - otherwise how would we figure out what product to use on uncooperative paint?
                        Dang....I hate those kind of come backs!
                        Don
                          Michael,
                          Serious question on doing test spots. Do you typically do test spots by hand or by (say) DA if that's the method you're going to use? Or do you do a TS always by hand to get a better idea of what product to use? If by hand is the case, do you then follow that method (by hand) with a DA and pad/product test? In "most" show and tell I have seen, it seems by hand method is what is used to perform the ts.
                          I guess what I am looking for is what method to best use for a test spot. I rarely do any job by hand and wonder if doing a DA ts is best if that's the method that will be used to do the vehicle. I have always done my ts's by DA/PAD/Product.
                          Hope that's not too confusing.
                          Don
                            Don, you should do your test spot with the tools you'll be using otherwise you aren't giving the paint or process a fair shake. The whole idea of a test spot is to dial in a product/process that will give repeatable results over the entire vehicle.
                            We once worked on a Ferrari 512BBi with original single stage paint dating back to the early/mid 1980s and it was just stupid delicate. Even M07 by hand left it looking hazy - go figure. We did so many test areas that we were running out of room on the hood!! If memory serves, the time spent trying to figure out a process took almost as long as buffing out the whole car!
                            It should be stressed, though, that super delicate paint isn't all that terribly common. Personally, this Honda and a couple of other Honda Fits that I've worked on, plus the Cobra linked to in the article and that Ferrari were the only cars I've worked on that were this delicate. Having worked on them though, I now have a good starting point reference when presented with something might be very delicate. Instead of starting my test spot with UC (which, honestly, in most cases is going to correct the vast majority of issues on the vast majority of paints) I'll drop down to M205 or M80. Maybe even start off with a finishing pad just to see how the paint responds.
                            Joe Fernandez of Superior Shine has the tag line "I am the paint whisperer." under his avatar here on MOL. That's really not too far off - the paint will tell you what it needs, you just have to listen. Your test spot is that initial interview with the paint to find out what it wants and needs. Corny as that sounds, it's true.
                            The good news is that most of the time you can get the job done with just a few likely combinations of products/processes. It's the head scratchers that cause frustration and take so much time to dial in.
                              Thanks Michael. I appreciate the return.
                              I do just that. If a DA is to be used, that's what I use for the test spot...if a rotary is to be used (RARE), that's what I dial in on. This latest post had just got me to thinking (in conjunction with others I've seen) that maybe I was missig out on something by doing a ts by hand/applicator.
                              Cleared up my question very well. Thanks again.
                              Don
