Please explain Pros/Cons between Rotary and Orbital Buffers
  • Please explain Pros/Cons between Rotary and Orbital Buffers
    I have a Sears 9 Inch Orbital that I've had for a few years (but haven't used much). The more I look online for info and advice on properly cleaning and detailing I see the mention of Rotary buffers.
    Can someone explain or send me in the right direction to properly use these buffers?
    Usually, for me, I use it to apply the polish and wax to the car, switching the bonnets with each application. I'll usually use the same bonnet to apply and remove the polish/wax as I apply to the entire car and by the time I've finished that step the original has dried sufficiently that a pass with the buffer cleans it off.
    JTMcD.
    JTMcD.
    We sleep peaceful in our beds because Rough Men stand ready in the night to visit violence upon those who would do us harm.......G. Orwell
    92 Dakota ClubCab 4x2, 08 1500 MegaCab 4x4, 92 Ford Bronco Custom 4x4, 08 Ford Escape 4x2
    Re: Please explain Pros/Cons between Rotary and orbital Buffers
    Well, I give you a few suggestions:
    There is a HUGE difference between a rotary and an orbital.
    Orbitals are meant to apply and remove products that have very low or no abrassiveness. They are meant to speed up the process of application.
    Rotaries are direct drive beasts - not really, but in the wrong hands, they are.
    A rotary has tons of power and is meant to apply very abrassive products with tons of power to break down the abrassives. Rotaries are used to remove series defects or wetsanding marks. They also use pads instead of the bonnets.
    Before making such a huge step, I would suggest getting a PC.
    As for your orbital use:
    You should switch to a clean bonnet before removing the product.
    Chris
    Dasher Detailing Services
      PorscheGuy997 covered the topic pretty well, give this a read to help understand even more...Rotary vs. PC vs. Regular Orbital Buffer
      Hope this helps!!
        It's been awhile since I've been online but Thanks very much for the reply and info.
        JTMcD.
          Hey Chris,
          Very nice explanation!
          Andy
          Andy M. Moderator
            Great explanation Chris. I would agree with going the route of the pc. They do a fantastic job, imho. Plus they are practically goof proof. The machine makes a tremendous improvement in your vehicles finish.
              This was written about 3 years ago and we should update it but it might help you...
              Can a Rotary Buffer like a Makita or DeWalt be as Idiot-proof as a PC?
              Then there's this one... it was written a few months ago...
              Learning to use the Rotary Buffer
                Rotary will do more defect removal then an orbital.
                Rotary will finish the paint to a much higher quality then an oribital.
                Unfortunately you need to really know how to use the rotary...
                  Here's a stab at a realistic explanation of what it means to buff a car out using a rotary buffer.
                  This tool...
                  The DeWalt 849 Rotary Buffer with the Stick Style Handle
                  Compared to this tool...
                  Sealy Orbital Polisher
                  Besides being a much more powerful tool and all the things that includes, using a rotary buffer will require a lot of upper body and back strength when we start talking about buffing out an entire car in one day.
                  It's easy to make it look easy to stand in front of the hood of a car and buff on a horizontal surface about waist high, but that and the trunk lid are the easy areas, the roof will usually require to stand on something to reach it and because you don't want to bend over to use a rotary on vertical panels for the rest of the car you're either going to be on your knees or your bottom, that is unless you have a floor lift so you can raise the car.
                  Now consider that if you're looking for show car results, not hack job detailing, then using a rotary buffer over an entire car is going to mean going around the entire car at least twice, the first pass being your cutting pass to remove all the defects and the second pass to remove any swirls left by the first pass.
                  Now after all this work, to really insure all the swirls are gone, most people will go around the car using a DA Polisher and some type of light cleaning polish or cleaner/wax, (so they've changed the action of the tool which means they've changed the action of how the pad is moving over the surface).
                  So that's 3 machine steps and you still have to apply your finishing wax assuming you're not using a cleaner/wax with the DA and stopping there, this being true you project is 4 machine steps. You could apply your LSP by hand but if you have DA Polisher then you already understand that the machine always does a better job than the hand so we're talking about a 4 step machine buff-out to your car.
                  How long will that take? Depends upon the size of the car, your goals and the condition of the paint that you're starting with; there's a big difference between buffing out a 1992 Mazda Miata and a 1957 Chevrolet Nomad Wagon, considering the Miata is mostly smooth body panels while besides being HUGE the Nomad Wagon has body lines across the roof and the tail gate that have to be addressed.
                  Many of the people that have attended our classes that move up to using a rotary buffer will do a panel a weekend, that is one weekend they will do the entire process to the hood, the next weekend they may tackle a door and so on until they've moved around the car and put the paint through all the steps. Of course this takes weeks and even months and after each panel is finished, in the future they have to wash, dry and in every way they touch the paint be careful so the don't re-instill swirls and scratches.
                  Does that help to explain what you're getting into when you ask the question...
                  Originally posted by JohnMcD348 View Post
                  Can someone explain or send me in the right direction to properly use these buffers.
                  Instead of telling you 'how" to use the rotary buffer we did our best to explain to you the reality of what it means to use a rotary buffer in contrast to using what we call a Traditional Orbital Buffer or Polisher that by comparison to what you wrote and to what I wrote is a cake walk.
                    Re: Please explain Pros/Cons between Rotary and Orbital Buffers
                    Excellent post. I GREATLY appreciate the info you passed on. I really kind wish I lived in your area so I could attend some of your classes. I'd even catch a road show class if they ever come my way. I've been waxing and cleaning my own vehicles now for over 20 years, pretty much using Meg's products to near exclusivity and I know 'm doing an OK job but can do better. I just need someone to show me the ropes.
                    JTMcD.
                      There's a lot of forums out there with detailing talk to read, and we alway encourage people to check them all out and then make up their own mind where they get their best answers and information.
                      We try to type up answers that enable people to go out into their garage and be successful and explain products, tools and procedures in ways that the average person can understand and apply to their situation.
                      Behind the scenes we are working on this for this year. It just takes time.
                      Patience....
