Hey Folks...
Finally tackling something I've let go far too long. Had a paint chip that was about 2mm across, decided just to leave it for the time being.
Well, the time being ended up being all winter, and a bit of rust started to form. I cleaned it out and applied some primer (just until I could do a complete repair), but I was stupid and didn't flake off any loose paint, so the rust came back
Just noticed how bad it was after a no-touch car wash (living in an apartment with no hose access *****), when some of the loose paint got kicked away by the pressure.
So, now I'm left with a pencil-eraser sized chip with some rust. Eek!
I've already ordered some Meg's 3000 grit (first time doing it, so I'm playing it safe with the grit, will just have tired arms!), have a sanding block to sand with, and have primer and color matched paint. I'm going to use the plastic toothpick applicator method, build up a couple layers of primer, 3-4 of paint, and 1 of clearcoat (probably unnecessary but what the hey), or however many it takes me to get it "bumped" over the surrounding surface so I can knock it back down with the wetsanding.
Couple questions though...
1. What's the best way to clean off the surface rust? Will Isopropyl alcohol + q-tip be enough? I plan on using a pencil eraser with 3000 grit glued to it in a little circle to clean out the worst of it, but I want to get all the traces out.
2. Is ultimate compound the best product to use right after the wetsand? I plan on doing ScratchX after it and then an all-in-one that shall remain unnamed
3. Should I even try to tackle this? Is there anything I can do that will make it more expensive for a body shop to fix? I figure they'd probably advise respraying the panel anyway, so no harm no foul, right?
Any other tips?
Thanks a bunch folks!
Any other tips?
