Originally posted by Blackheart
View Post
first of all,although you have a new car,you might have to clay it.After you wash it,run your hand over the surface(gently,palm) and if you can feel any roughness,then you should clay it.chances are,the sides won't need this as it is a new car.
I've been using meguiar's for about 8 years now and havn't had any bother.You have selected a good brand for protecting and having a car that looks good.
After that you could proceed to the waxing(being a new car).You might not have experience to determine if it requires polishing.This you will have to do in the future.
A great set up is Auto shampoo(Dish soap is not good for your car,it will remove wax and also contains salts),I personally love the deep crystal 3 step system.you can omit step 1 and keep it for the future.
This is ultra important! Use proper applicators which are new and clean and wipe off with terry towel(100%) or microfibre.Do not use old rags because if they are contaminated,they will carry on to your clearcoat and scratch it.Work in the shade.If you have to work on your car near a busy street as i do,this creates a lot of dust,so if you are polishing or waxing your car,and you are taking your time,you might want to give the panel that you are about to work on a spray and wipe off with quick detailer.Then start your work.Also keep wax away from ABS plastics that are unpainted,but give them a coating of plastic protectant.If left for too long they will fade and turn grey.
As far as an orbital buffer goes,you do not need one.With time you will be able to determine if one is neccessary or not,but you are a long way from that stage.
If your car gets dusty every day and you want to wash it,use your conditioning shampoo in a bucket of tepid water.It's not neccessary to use Hot water.Try to rinse off the soap using a steady stream as this will help the water to run away.I dry my vehicles with a chamois,some prefer micros.I personally have never had any problems with chamois and they are 15 years old!The choice is yours.
Your choice of wax is fine.Carnauba i found lasted longer.if you want your wax to last longer try NXT 2.0.i find using quick detailer on aregular basis solves the problem of longetivity,as my car is never garaged.
anyway,good luck and hope you upload some pics!
