Re: Used swirlX for the first time
First, used correctly, SwirlX nor any of Meguiar's paint care products will damage paint, we've been doing this for over a hundred years so we have quite a bit of credibility built up on the matter.
It's more likely that you removed some of the lighter swirls and now the deeper swirls and scratches show up more easily to your eyes. This means they were always there, not put in by SwirlX
I posted about this on the first page of your thread.
A paint cleaner is NOT the last step. Applying a wax or a paint sealant is the last step and the idea is as you work through the steps the paint get better and better looking, this implies that it doesn't look it's best till after the last step. I think I touched on this idea in this thread already also?
Follow me on this,
If a product has the ability to remove swirls and scratches, another way of thinking of this is the product has the ability to remove a little paint in an effort to level or flatten-out the surface.
If said product can remove paint it will certainly remove any micron thin layer of wax residing on the surface in the first few passes, it's really of no concern.
IF you want to try again, wash and dry the car or wipe the car clean, and then do a Test Spot.
Make sure you can apply and remove SwirlX to one small area and perfect your technique for working by hand and be sure you're getting good results before going over the entire car.
If SwirlX didn't remove all the swirls and scratches the first time regardless if it was because of bad technique or some other reason, then it could be,
You need to use a more aggressive product
The swirls and scratches are too deep to safely remove.
Again, if this is a daily driver then it's usually not a good idea to aim for 100% perfection as the wear-and-tear caused by daily driving will just instill more swirls and scratches into the future.
Originally posted by Lagos
View Post
View Post
View Post
View Post
