How I keep my car looking its best between washes
  • How I keep my car looking its best between washes
    Heyy all,
    I wanted to share with you guys how I keep my car looking its best in between washes.
    The products I use are:
    -Last touch 1:1
    -NXT glass cleaner
    -Hot shine dressing
    - Supreme Shine MFs x 2 One for cleaning and the other for finishing
    - Armor all glass towels
    (above picture was taken after surface was cleaned )
    This is how dirty my car usually gets before I use this method. I wouldn’t try this if it were dirtier than this, to avoid swirls of course.
    Too start , I fold my supreme shine MFs 3 times to get something like this
    Doing this will give you 16 clean sides to work with.
    Now to actually clean the car, I spray Last touch on one section at a time about the size of half a door panel. About as much as in the picture.
    Next, I wipe horizontally across the surface. I only wipe each section once. I find that one swipe is all it takes to clean the grime off the paint.
    Then, I take the second Supreme shine MF towel and gently buff away the residue and streaks left over from the Last touch.
    I do the whole car ( including the door jambs) using this two MF towel technique, I then finish off by cleaning the glass , wiping down the wheels and dressing the tires if needed.
    Here are some pictures of the results:
    And here’s the cleaning Supreme Shine MF towel after, both sides are similar. I only needed one MF towel to clean because of the way i folded it , but use as many as you need.
    Thanks for looking and feel free to post your techniques and tips !!
    Last edited by Ravi_1992; Jun 18, 2012, 08:56 PM. Reason: most of my post is missing
    Re: How I keep my car looking its best between washes
    Is it a typo Last Touch 1:1? That is diluted ratio for clay lube. If not, wow!
    2010 Subaru Legacy GT - Graphite Gray Metallic
      Nope , no typo . I like using last touch cut 1:1 with distlled water. Still seemed to lubricated the surface really well while I was cleaning. I will eventually buy a bottle of UW&W anywhere to use instead.
        Thanks for sharing!
        My process is very similar, although I'll use LT diluted more like 2 LT:1 H2O. And I'll use M135 (undiluted) every other time.
        I like your idea of just doing one swipe with the initial towel. I have a habit of overdoing things, hence increasing the risk of creating swirls. I must try it...
          Doing just one wipe seemed to work very well , my second towel was complety clean after words; just moist with LT .
            I like your idea of folding the towel. Thanks a lot for sharing.
              I've been using ONR (2 oz with 32 oz water) lately similar to how you're with LT 1:1, the lower parts of my cars I've been using UWWA.
              I've also been using UQD in a similar way too....may have to try the LT 1:1 too.......I have too much stuff on hand!
              Btw....great looking Cruze!
              "STRIFE" aka Phil
                I like LT 1:1 too. I like it better than using it straight. When used straight I get streaking, 1:1 is perfect. I would add some Megs UQW or D156 to your arsenal for maintenance too.
                  Great write up. Thanks for sharing with us. Im gonna have to try folding my towels that way.
                  For my wagon I use M135 and for my sedan I use M34.
                  2011 Jet Black 328i Touring
                  2007 Jet Black 335i Sedan
                    Thanks for all the kind words guys !
