This apparently is a homemade carpet extractor (Not Mine, Found Pics On Internet) that I'd really like to know if this would work any good?! I really don't have a couple grand to throw out right now for a hot water carpet extractor and I hate using Bissell's Little Green Machine. I have my own mobile detailing buisness and really need a good way to clean carpets of customers vehicles. Heres the Pics.
This is a picture of tubing coming from a Shurflo diaphragm pump, going into a old "greased lightning" 5gallon bottle which is used as the solution tank with water and carpet cleaner.
This is the Shurflo diaphragm pump that is used to pump solution water out of the hose going through the platform, and goes on through to a 40ft tube
He has it hooked straight up to the vehicles battery, using a toggle switch to cut it on and off
The other side of the pump with the 40ft hose.......
.....that goes all the way out the back of his mobile detailing van....
...and here's where it looks like he added some couplings to the end of the hose, kinda like ones that are on pressure washers. Shop Vac comes into play on next picture.
He said he bought a carpet extractor wand tool for like $70.00 and fit it into his shop vac hose like it was made for it! He even cut a hole through the end of the hose coupling so that the tubing thats pumping the carpet cleaner solution can fit inside to hook up directly to extractor wands nozzle sprayer
BUNK OR COULD THIS WORK AND BE WORTH A DAYUM!
