Just a few of my home made tools i use:
  • Just a few of my home made tools i use:
    Hello Everyone,
    Over the years I have made a few of my own tools I use when performing general Detailing, and haven't seen a few of them posted on here, so I figured I would share them with you guys as to try to hopefully make life a bit easier for someone.
    1.To avoid getting any tire dressing on freshly polished wheels, I make a cardboard cutout to the inside diameter of the wheel lip, cut two holes in the center for a handle, and cover the entire surface with duct tape. I have a template for 15" through 22" to make quick work of dressing tires without any chance of getting anything onto the wheels. Its cheap, easy, and works quite well.
    2. Q-Tips - I add a small amount of Quick Detailer to the bottom of an old aspirin bottle, and place several Q-Tips on end to soak the chemical up for a period of 24 hours prior to Detailing for use on hard to reach areas on the Exterior of the Vehicle, and related painted surfaces. Then I add a small amount of a good APC Product to another bottle, and add another set of Q-Tips to that as well for use on Interior surfaces. Again, another cheap, and simple tool that makes life easier in tight areas.
    3. Paint Brushes - I use a series of Paint Brushes some of which are full bristled for use in cleaning various surfaces, and some with the bristles cut down to approximately 1" for working with Trim components. In addition I also like to use Liquid Shoe Polish Applicator Bottles with the foam pad on top for easy use of water based dressing on exterior side moldings.
    4. Polishing Billet Grilles - One of the ways I like to make life easier when polishing Billet Grilles is to use a two small cuts of ultra deep pile carpeting. I use one square por applying, and rubbing in white fine Jeweler's Rouge, and after the chemical has dried to a dark haze, I use another clean square to polish the product to a high shine. This is very effective for these types of Grilles, as well as various types of wheels, and other related types of surfaces.
    5. Bottle Brush - I like to use a simple bottle brush with a home made extended handle to clean tight wheel wells on vehicles that have been lowered, and have an excessively tight gap. These types of brushes are designed to fit into tight places, and make quick work of cleaning these gaps.
    And last but not least,
    Since it is not discussed very often, but is a useful little trick, if you ever accidentally get wax residue embedded into any trim work, and you are not able to get it out, the peanut oil content in creamy peanut butter will lift the reside to the surface with ease.
    Anyways, I hope this might help someone out their. Go easy, and I will catch you all later.
    Candyman
    Re: Just a few of my home made tools i use:
    Don, glad to see you out and about again I was just wondering the other day how you were doing.
    After seeing you talk about this on the Crusier forum, I tried it out and it got the wax off, but it left me with some peanut butter residue on the trim I couldn't quite get off. I basically exchanged one stain for another.
    Now, I know the suggestion is to use peanut butter because it is easier to spread than the oil alone would be, but would using peanut oil on a Q Tip or other small applicator do the same job with out leaving behind the gunk?
      Hey their William_F,
      Its great to see you here as well! How was Christmas your way? Hopefully not too cold.
      Sorry to hear about your little glitch here. That's not usually sposed to happen, but sometimes things just come up. Such as life in the ever changing world of Detailing. I have been devoting a lot of time to tweaking my closed loop wash rack / water filtration system concept for the shop, and haven't had much chance to kick back and hang like I used to, so once again I am back to playing catch up.
      Anyways, try n pick up just some peanut oil instead of going with the full on peanut butter, and try that. The peanut oil content is the part of the equation which lifts the wax residue anyway. Just fold a clean microfiber towel into four, apply a small amount of peanut oil directly to the towel and it should clean it up nicely. As always, if for some reason that doesn't correct the problem, please let me know and I have plenty of other tricks in my bag.
      Go easy, and let me know how you make out with it.
      Candyman
        APC, M39, M40, and APC Plus do a good job of removing wax from trim.
          Thanks for the clarification on the PB trick. The looks I got from the neighbors made it all worth it LOL
          It was unusually cold here. We had the first white christmas in a number of years. The roads were icy and nasty. We actually had a minor fender bender in the CRV. A car skidded into us sideways, which caused us to skid and then when I corrected, we skidded some more and hit them, then they side swiped us again. We got a crease in the front pass side fender behind the headlight and our rear pass door is messed up.
            White eraser is very good to remove wax on plastics too
