A look into Pad Priming - The Kevin Brown Method
  • #31
    Re: A look into Pad Priming - The Kevin Brown Method
    Chris,
    on the pad cleaning, I usually clean the pad after every panel or every other panel, depending on the condition of the pad. Ever since I bought a pad washer that's what I use to clean the pads with on the fly. Would you re-prime the pad after using the pad washer to clean it with? It will be slightly damp (I usually hold up a towel to the pad to remove the excess moisture after spinning it in open air on the rotary). I think I read where you have to change the pad and let that one dry completely?
    • #32
      Yes, after cleaning the pad with a soft brush, the pad should be reprimed. There will be some residual product after cleaning, but it is a good idea to make sure there is fresh polish in the pad.
      I prefer to let the pad dry before buffing. There will be some residual water, which could thin out the polish.
      Chris
      Dasher Detailing Services
      • #33
        Originally posted by resek View Post
        Thanks a lot Chris!
        Very good info there!
        Good thing about M95, i was about to use the "priming" method for it ... but since it's a diminishing abrasive, i won't use this method.
        A thread about DAT vs. SMAT and a post from Mike Pennington regarding the type of compound that M95 is.
        What's the difference between Meguiar's Super Micro Abrasive technology and Meguiar's Diminishing Abrasive technology? (http://meguiarsonline.com/forums/showthread.php?t=23748) Hello guys, Can you tell me the differences between Meguiar's Super Micro Abrasives technology and Meguiar's Diminishing Abrasive
        M95 vs. M105 threads
        Difference between M95 and M105 (http://meguiarsonline.com/forums/showthread.php?t=26534) I am looking for a strong compound and have seen both the 95 and 105, and I am not sure of the differences between them. Both are able to remove 1200 grit sanding marks, and the ecommerce site does not list any differences. Also, from
        Hi guys. I getting ready to place a big order to replenish my usually supplies and I want to try either M95 or M105. Usually, I would agree with everyone and just try both but to me, they appear to be very similar products. I've been doing a ton of research on both and this is what I'm coming up with: M105: slightly more
        I bet M95 would work with the "KB method".
        • #34
          Thanks Terry for those links!
          I'll give M95 a try with "KBM".
          • #35
            I am sure many were thinking spray to prime the pad,thanks for the clarification.I have always primed with spray before priming with the working product.
            roger
            • #36
              Does anyone have any of the above photos for the KB method explanation/procedure hosted somewhere differently from Photobucket?? For some reason my computer hates Photobucket links... HELP!!!?
              • #37
                Hey everyone,
                I thought I would give you guys a little sample of Kevin's paper. One of the most important topics covered is pad priming. Although it may seem simple, I wanted to clear up some confusion.
                When I refer to pad priming, I am referring to the liquid that will be used in polishing - not a spray detailer.
                M105, M205, M86, D151, SwirlX, ScratchX 2.0, and Ultimate Compound use abrasives that are uniform and non-diminishing (SMAT). That means that they are very different than most products that use abrasives that break down. These products that use non-diminishing abrasives rely heavily on the lubricant. If there is too much lubricant, then the cut will be reduced because the abrasive is floating in lubricant. If there is too little lubricant, then the product will "flash" very quickly and you will need to reapply product.
                The best way to utilize the products listed above (non-diminishing or SMAT) is to prime the pad. To do so, take the product and pour some on the pad. Then, rub it in. You are not trying to spread butter on toast! Aggressively rub the product into the pad until the entire surface is covered.
                To show the method, I chose M205 and a W9207 finishing pad.
                Below is an example of a poorly primed pad. As you can see, the product has completely filled in each of the pores. This will waste product and reduce the cut.
                Here is what a properly primed pad should look like. The pores are not filled with product, but there is still product available in the pores.
                To give you a better idea of what the pores look like, I took a macro shot of the above pad properly primed with M205.
                Hope that helps!
                Chris
                • #38
                  THAT is fantastic.. Thank you so much Chris! You sir, are a master of your craft Thanks!
                  • #39
                    I have a question. Would there be any benefits by priming an applicator pad (working by hand)? I plan on doing this this weekend using the Hi Tech Applicator pads and UC.
                    Wife say's I'm "obsessed"!
                    • #40
                      I doubt it. When working by hand, the product should easily spread on the applicator. If it does not, then you do not have enough product on the pad.
                      Chris
                      • #41
                        I know this is an old thread, but I was recently taught to prime the pad with something like Final Inspection. A couple sprays, then apply the product.
                        The problem I see with priming the pad using the method like this, is the amount of product you're using. I was also taught to clean the pad after a panel because of all the debris and paint gets stuck on the pad. So if you have to re-prime again after each panel, wouldn't that be a lot of wasted product?
                        2006 San Remo Red WRX TR
                        2005 Ford Ranger XLT
                        Detailers clean places nobody see. Detailer see's things nobody else see. But if you ask a Detailer to see how a dress looks on a woman, they are blind.
                        • #42
                          I think you only prime a pad when you get a new pad.
                          • #43
                            Just to confirm, the use of M34 is recommended only for rotary polishing. However, I find that a spray detailer can dilute the non-diminishing abrasive liquid and reduce the cut. If you are just using a diminishing abrasive product, then there is nothing wrong with using a spray detailer.
                            It really does not use a lot of excess product. Instead of applying a full circle, just prime the pad and add two or three dots of product. You should be good to go after that.
                            It's always best to clean the pad as often as possible. I clean it at least one time per section. After cleaning, I will prime the pad and add a few dots. The idea is to make sure there is fresh product available at all times.
                            Chris
                            • #44
                              Chris, have you found that the amount of polish you use per section (2 or 3 dots) also applies to SwirlX and Ultimate Compound?
                              --Al Kimel
                              • #45
                                Thanks Chris.
