2-Bucket or 3-Bucket Method?
  • 2-Bucket or 3-Bucket Method?
    Newbie here. I've read about the 2-bucket (0ne for soap and the other for rinse) But what about a 3rd bucket just for the wheels? Does this make sense or completely unnecessary? Thanks in advance.
    Re: 2-Bucket or 3-Bucket Method?
    Since coming here, I use the 3 bucket system, I fill up a bucket with soapy water as normal then scrub the wheels (both buckets turn black) then dump and start fresh for the rest of the car.
    Hate to get some of that grime from the wheels onto the car!
    I live in a rural area and my cars get dirty.
      Two buckets, then when finished with the body, do the wheels.
        Saves water too!
        --VoicesInMyHead--
          I have used the 3 bucket method for years. Start with the wheels and finish with the body....less time for water spots to happen.
          -Bob
            3 buckets here also.
              Originally posted by VoicesInMyHead View Post
              Saves water too!
              Rob A.
              '07 Kia Optima (Gold)
                3 bucket here to.
                The Best Last Step, is the step backwards you take to admire your work!
                If you use #7 on your car, you're not in good company... you're in GREAT company!
                  I like the three bucket method myself. Found I could get the wheels done out of one and then move on to body from top down with the other two and get the whole job done much quicker. We've got a Lexus IS that generates tremendous amount of brake dust, no reason to risk getting that on the paint.
                    I watched the video on the net with mike phillips washing the mini cooper. Where can I get the three bucket system with the dollies.
                    thanks
                      Saves water too!
                      Same here. Three buckets seem to be overkill. I can see if your washing multiple vehicles but two are just fine.
                        One bucket here. I know, I know!
                        Scott
                          2 bucket here- I have no need for a bucket for the wheels.
                          I use a combo of rinsing, foam-based spray product, and then brushes...no need for a bucket on the wheels.
                          Then the typical grit-guarded 2 buckets for the body. Starting at the top, and working my way down the body in thirds.
                            thanks
                            Grit quard has the dual buckets, im assuming you can attach a single unit to it.
                              ehehe, yep one bucket system here. too busy buying neat new products instead of buying another bucket.
