New Way To Apply Paste Wax To PC Pad
  • New Way To Apply Paste Wax To PC Pad
    Hey everyone,
    I saw this on another forum and thought I would give it a try. I took an old deoderant container cleaned it out with HOT tap water and soap. I then used a double boiler to melt some collinite fleet wax and poured it into the container and chilled it in the frig. Here is what it looks like.
    Andrew Parshall
    2013 Race Red F-150 SCREW
    Re: New Way To Apply Paste Wax To PC Pad
    Wouldn't the extreme temps from melting the wax harm the wax? I was thinking about doing something like this, but felt that the extreme temps would alter the characteristics of the wax.
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
      The ingenuity of the online enthusiasts never ceases to amaze us.
      Just to note to everyone that will ever read this in the future, this is not a Meguiar's recommended or endorsed procedure.
        Mike, any comments as to wether or not it would hurt the product by doing this? If not, this is an awesome idea! I have started using #16 and it's a pain to get on the G100's pad. Something like this would make it an easy process.
        Thanks,
          Just don't get confused and use the wrong one in the wrong place. Don't think #16 would work good in the pits or Speed Stick on your car.
          Scott
            Re-heating and then liquefying and then pouring a melted wax into a plastic container not specifically developed to have hot wax poured into it will likely change the performance of the product.
            You're on you own on this one. As we commented on your other thread about how to get M16, or any paste wax onto a foam buffing pad for application with a dual action polisher, there is no Simple-Simon method.
            How to transfer product from wax tin to pad?
              Doesn't hurt to ask
              Thanks for the reply Mike. I waxed the truck yesterday for the first time with the #16 and the PC combined. It was a pain to do, but it did help to keep a nice thin, even coat with the #16. I've done it by hand before, and this was better than doing it by hand, but still a pain to get the wax from the tin to the pad.
                melt the wax put in to a contaner
                i can try with a very cheap wax not meguirs
                alberto gorin
                known as gorin002
                  Well, if you think about it, the way they get that stuff in the can in the factory is to inject it as a hot liquid. And it does hold up after being shipped and stored at pretty warm temperatures. So as long as you don’t go too crazy heating it seems reasonable that there shouldn’t be much difficulty.
                  Obviously, any volatiles in the mix are going to start flashing off so it’s a good idea to keep the heat as low as possible and not leave the wax exposed to open air too much for too long.
                  The again, you could just punch the applicator down into the wax cookie-cutter style without heating it at all.
                  PC.
                    PC.
                    Excellent idea!
                    You guys are so smart
                      Originally posted by n737nc View Post
                      Excellent idea!...
                      Only a refinement.
                      Your idea of using the pop-up container in the first place was brilliant!
                      PC.
                        What are the chances that Meguiars could put out product using this type of applicator ? Would it be worth making it available to the buffer crowd ? Looks like a slick idea.
                        Live like you're not afraid to die.Don't be scared, just enjoy your ride. Chris Ledoux RIP
                        PAUL SPARKS / Distinctive Auto Detailing
                        317-513-4678
                          how do you elt the wax ?
                          alberto gorin
                          known as gorin002
                            Hey everyone,
                            Like I said I wanted to try something to see if it would be easier for PC use. I understand that it is not recommended by Meg's and that is the reason I used my collinite Fleet wax. HAHAHA. I melted it by boiling water over low medium heat outside and then I placed the container that was holding the scooped out wax into the boiling water and slowly melted it.
                              Originally posted by onawrxhigh View Post
                              Hey everyone,
                              sory so boiled water put can in it wax melt ?
                              take a spoon and put wax in a contaner am i correct
                              alberto gorin
                              known as gorin002
