Correct compound / polish for plastic grill wet sand
  • Correct compound / polish for plastic grill wet sand
    I just painted a plastic grill with factory rattle cans. The grill is plastic, but I bought it new from dealer already painted and cleared. However it was the wrong color for my truck so I scuffed it up good, prepped it and applied paint and clear per instructions.
    Instructions go on to say use 1500 wet sand to even out the clear and know down any dust etc...
    Question is, once I wet sand (I've got 3M or harbor freight....difference??) what is the best meguiars products to finish?
    Ive got Ultimate wax for final , and scratch x 2.0 if that would work for a compound. ?..?.
    I would go with 2000 grit and M105.
    You might have an easyer time getting Ultimate Compound which us the same just less dustyer.
    DetailingByM.com
      Re: Correct compound / polish for plastic grill wet sand
      I would even suggest finishing out with some 3000 grit sand paper if you can.
      Are you going to use a rotary buffer? If so I too would say M105 followed by M205 to finish out.
      Thoryamaha919 AKA Evan
        Yes, rotary buffer.
        I have a couple red pads from Megs, will those work? A lot of the grill isn't going to allow the buffer access.
          Originally posted by PdxRealtor View Post
          Yes, rotary buffer.
          So... red pad OK?
            Yes a red pad will work, but wool will cut faster.
            DetailingByM.com
              Cool, thanks. I do have some wool I could use.
