Orange peel and wet sanding, Meguiar's buffing products
  • Orange peel and wet sanding, Meguiar's buffing products
    I recently painted my 72 Skylark a midnight blue with Single Stage paint. Overall it looks nice, with the exception of the Orange Peel throughout the paint job. What I did so far (only on the trunk lid, as a trial) was I wet sanded it with 2500 grit paper.
    After Wet-sanding, my midnight blue color car was a powder blue color. There were a few spots of darker color, indicating I did not wet sand completely smooth, but a majority of it was smooth.
    Then used W7000 Foam Cutting Pad with Meguiar's Mirror Glaze medium cut cleaner, and finished it with Ultimate Compound.
    After using the compounds, there was still orange peel and some haze.
    What else can I do???????
    Ethan
    Re: Orange peel and wet sanding, Meguiar's buffing products
    Did you sand your paint by hand or with a D/A sander ? Machine sanding leaves much more even surface.
    Normally after wet/ damp sanding rotary buffer with either wool or foam cutting pad is called to a scene to remove sanding marks (wool cuts faster). Aggressive compound is also needed to ensure all deeper tracers removal, like M105 Ultra Cut Compound. The other option on fresh paint is to use Meguiar's So1o System and M86 Cut & Polish Cream (also with a rotary buffer).
    Make sure you leave paint surface even with orange peel effect fully removed. If needed step up to 1500-2000 grit sand paper.
      I sanded it be hand. I used the foam, because I didn't want to cut into the paint to fast (this is my first time using a buffer)
      So I should:
      1- re-sand, basically making sure that the sanded area is uniform in color and texture.
      2-hit with a wool pad and ultra cut compound
      3-then move to foam pad and either the medium cut or ultimate compound
        Step 1 - Sanding - to make your paint surface as even as possible to get perfect reflection and remove orange peel (wavey texture), many detailers start with 1500-2000 grid and then follow up with 2500-3000 for final step;
        Step 2 - Sanding mark removal - best approach: rotary buffer with wool/ foam cutting pad (if foam used watch out for heat build up), M105 Ultra Cut Compound or M86 Cut & Polish Cream with So1o wool pad (burgundy or yellow); if rotary buffer can't be used - D/A polisher with M105;
        Step 3 - Swirl removal/ Gloss restoration - aggressive compound may leave some swirls behind, M205 Ultra Finishing Polish, M83 Dual Action Cleaner Polish or M80 Speed Glaze with polishing pad should be used in this step (or M86 again with So1o diamond foam yellow pad);
        Step 4 (Optional) - High gloss polishing/ Paint jeweling - either M205 Ultra Finishing Polish or M07 Show Car Glaze with finishing pad should be used;
        Step 5 (after at least 30-60 days) - Protection/ Wax - fresh paint needs to fully out gas before applying wax/ sealant.
          Thanks for the feed back. I'll let you know how it works out. Hopefully with some great pics too.
            I think Greg pretty much nailed it. (though I do feel hand sanding can create or move level finish)
            I would just knock down the majority of the high points with 1500, follow up with 2000, maybe 2500, and then 3000. After that it should polish out rather easily with a Solo wool pad and some M105 or M86. Follow that with 2-3 more refining steps and your good to go.
            A few that I've done for reference.
            1960 Impala, Full Wet Sand and Buff. So this is another car that my mentor recently picked up for resale at a local auction (yes it sold). The car appeared to have been repainted several years ago, but it was never actually wet sanded and buffed after the repaint. Overall the car was in very good shape, but the paint really
            1968 Pontiac Firebird, Full Wet Sand and Buff. This fine example of classic muscle actually belongs to one of my dealer accounts from back in the day when I worked for a high volume shop. The owner had purchased the vehicle as a personal collector/project car, and like most restorations, it has been a long tedious process over
            ***Let me first start by saying that this car underwent a full repaint and that this is NOT something I recommend you do on a factory painted car to remove orange peel.*** This is actually my fiancée and the car, which got hammered with over $9k in hail damage! My father works at the body shop where the work was done and I
            Rasky's Auto Detailing
