Clear Coat Sanded Through by Bodyshop!
  • #31
    Re: Clear Coat Sanded Through by Bodyshop!
    Top of the line clear coat is expensive Make sure they don't use the cheap back shelf brand.
    • #32
      Hi Invisible,I remember your original thread about the glue.Sorry to hear about all the hassle.One problem after another.Unfortunatley,dealership bodyshops sometimes don't do the best of jobs for individual cases and concentrate on their contracted work with the dealerships.Not because they don't know what they are doing,but they do too much......'time is money'.Another point to watch out for,if this is the case,is to make sure they remove any badges from the hood,if you've got one,and not just simply mask it and paint around it.This can leave a tiny edge that can peel a couple of years down the line.
      I prefer to search around for good bodyshops.You,don't have this option,though.I tend to stay away from bodyshops that have ties to dealerships,not because they are bad workmen,but because they are not thorough enough.
      Hope it works out all right for you.
      • #33
        Thanks for the comments!
        I am actually not too concerned about road chips and the quality of the clear coat. All Crown Insurance Accredited Bodyshops in British Columbia must meet a quality standard, on both material and workmanship. My original bumper was repainted by a local bodyshop for rock chips. The factory bumper was filled with chips, while the newly painted bumper has no chip so far after three years. That's an obvious improvement over over the factory paint.
        I understand that quality can be an issue when it comes to bodyshops in different parts of the world. But in British Columbia, which has a monopolized Crown-Owned Insurance company, bodyshops have very strict requirements to work with. This bodyshop owned by a large corporation is one of the biggest Crown Insurance Accredited shop in the region.
        Also, the bodyshop assured me that factory equivalent clear will be utilized, a minimum requirement for all bodyshops accredited by the Crown. It is Duplicolor, I believe, as there are a lot of Duplicolor banners and posters inside the shop.
        However, I have had experienced another bodyshop creating some sanding marks in the primer of my daily driver's hood, causing very slight paint to distortion in the corner of the hood. That is my main concern in this case.
        The shop indicates that they will blend the nearby fender top to minimize the effect of color mismatch. I hope that is an indication of their commitment to quality. Fingers crossed! I have seen cars repaired by this specific bodyshop, they are all top notch work. However, I was particularly disappointed by their wetsanding procedures they performed.
        I must be thinking too much.
        • #34
          post up once you get it back
          Hitachi SP 18VA & PCXP
          Rides: 94 XJ & 04 Explorer XLT
          • #35
            Just got the car back. The workmanship isn't the best I've seen in my life, but the bright noon sun, it doesn't look bad at all. There's no apparent paint mismatch. However, under my garage light, I see some very slight orange peel. Oh well. I expected it, the orange peel is almost like that on the trunk of my BMW.
            The painter who did my car came to talk to me and explained what he did. He said he used an 800 grit sandpaper to remove the old paint to avoid sanding marks. He claims that many painter in the industry choose to use 400 grit paper, which leaves sanding marks. He personally chooses 600 or 800 for the job. He also ensured that I was happy with the job before I leave. Under the sun, the paint looked flawless.
            At this point, the paint feels very soft. The paint hasn't been polished or waxed because of that. Like most new paint, the finish isn't very smooth or refine. It could use a polish to refine the surface slightly to bring out the gloss.
            My question is:
            1. When should I clay/polish the new paint?
            2. Should I use M105 to sharepn up the paint a bit? or would SwirlX/M205 work just fine in this case?
            Pictures to come after I wash the car after dinner.
            • #36
              My question is:
              You should not need to clay fresh paint
              If there any dirt nibs or peel areas you want to correct use 2000 uni grit wet and than buff with 105.
              After you wet sand let it breath for a day prior to buffing to let the solvent escape than buff with 105.
              You can top off with a polish # 80 or 7 or 205 but no wax or sealent 21 for 60 to 90 days
              • #37
                Glad you got your problem solved.
                maybe not the best of jobs,but acceptable.Seems you got a decent guy.I would have thought 400 a bit heavy too,just to sand down a coat for paint prep.
                • #38
                  Thanks Shyneman123 for the advice. If the peels are not too bad, can I simply use M105 to sharpen the paint a little?
                  Yeah, it's not the best job, but at least the painter I dealt with seemed to have the right attitude. You can't get mad at a person with the correct attitude, although I knew he could have done better... I don't know. So far, in my life, I have dealt with many bodyshops. So far, none of my experiences has been perfect. After any visit to any bodyshop, there were always issues that needed follow-up... be it moulding falling off, excessive orange peels, bumper not fitted correctly, window rubber seals out of place, you name it.
                  This time, I find some sort of sanding marks on both my headlights. At first, I thought those marks were waterspots, clear coat overspray, masking tape residue. I tried claying the marks, rubbing it with alcohol, and even paint thinner. Then I noticed it was sanding mark.
                  I tried getting them out using M105 with my PC7424XP and yellow LC Pad with 5 passes at speed 6. It improved a little, but still there. I finished up using PlastX and it got really better. Perhaps I will try wetsanding the headlight a little tomorrow.
                  • #39
                    As promised, some pictures:
                    See the bumper/fender paint mismatch? It is only visible under fluorescent lighting. The bumper was repainted two years ago for rock chips. The bumper paint job was blended with right fender. This time, when the hood is repainted, it is blended with the right fender yet again. So... Now one side of the fender doesn't match the bumper. The hood matches with the rest of the car nicely, it's just that the issue is solely caused by the repaint of the front bumper. The mismatched front bumper was only hidden by paint blending of the fenders. Now that the correct paint has been used on the hood and fender, the mismatched bumper is clearly visible. Sigh... after the windshield incident, this car will never be loved the same way ever again!!!
                    Time to trade in for a G37 coupe or 370Z. Or just drive the 335i instead.
                    Mike Pennington was correct... it is sometimes better to live with a little defect (windshield urethane stuck on the paint) than to have body color mismatch, quality compromised, etc.
                    One thing to consider, the bumper had a few passes of M205 and it has a VERY deep, dark gloss to the surface. The fender, on the other hand, has never been treated with polish of any kind, and is not very deep, although very shiny. Performing the same M205 treatment to the fender may darken the fender and deepen its gloss to match that of the bumper. At least I hope!
                    In this angle, it is not obvious at all. Neither is in the sunlight.
                    • #40
                      Did they say you could wash it that soon? When I had a panel on the Jeep repainted, I couldn't wash it for a month.
                      Might want to call them.
                      • #41
                        They didn't tell me. But I am under the impression that all baked panels can be washed. All the bodyshops washed my cars after they have been repainted.
                        • #42
                          Man, this just chips my grill! I have to chime in here and share an experience, driving two blocks from home in my brand new black Nissan Titan 4X4 with three kids in the car an 87 year old lady who's license, and insurance, had been revoked two weeks prior for flunking her eye test, turned left in a 4-way I was approaching at about 40 MPH. The truck had less than 1k miles on it. A new full front end cage bumper saved us, but it ended up in the body/repair shop, ironically, right on the corner where the accident occurred. Don't mean to get long winded, anyway, I had been using these guys for years for engine work I myself wasn't equipped for. Good shop, did ALL the cop cars here in Santa Monica. So a few days later, my truck is done, left fender/quarter panel looks great! Hood looks great! Wait a minute, WTF! The skid plate hasn't been replaced! No worries...Two days later I get the call. It looks great! wait a minute, WTF! The steering wheel is like, three inches off center! Now, though I am very calm, I begin to recieve a bit of the attitude...I here a guy call me petty under his breath. I ignore it. Later that day, I get my truck. Its perfect, or so I think until I wash it a week later and see that they have taken steel wool to my ENTITRE TRUCK! Now I am mad! I drive two blocks to the shop and find no one at the counter, and in my search for the owner, notice for the first time that, because the entire lot is building, sort of like a small warehouse, every car being worked on in the body work area, which I had never seen before, is covered in white powder! And I mean EVERY CAR, maybe fifteen or more, is literally hidden beneath bondo fallout from the sanding going on inside! Without telling him the nature of my business, I bring the owner, who was noticeably purturbed at seeing me, out to my truck and say, "Can you explain this?"
                          He denied ALL culpibility. I took pictures of his operation immediately with my cellphone, and filed suit. He offered to settle out of court, and repaint my brand new black truck. I said no thank you. I won the case, and the judge sided with me, saying I would have been nuts to let them touch the vehgicle after so much neglignce. See, judges know more than anyone how revenge works. Of course I took it somewhere else at a cost of nearly 5K. It looks as good as new. After hearing your story, if I were you, I would sue. The LAST thing I would do is give them access to my car! God only knows what hidden damage they'll do! Take it somewhere reputable, get a proffessional analysis, and bring it all to small claims. You will win, trust me, and all you will lose is your time. Saddly, these days, more often than not, it makes no differance if your nice, or irate. The simple fact he sounded suspicious over the phone should tell you all you need to know. Any responsible, decent business owner would have been courteous and reassuring, letting you know that he/she would take responsibilty for any damage they might have caused. Being a man who has owned three small business's, I have had my share of complaints, and ALWAYS handled them that way! Anything less, IMHO, is clear sign of dishonesty. When one takes pride in the work they market, they back it up like a proffesional! Furthermore, you had EVERY RIGHT to be VERY ANGRY! A car is no small financial investmant, and for one who takes pride in their vehicle, it is also an investmant in time for proper maintenance. I dont care if the blemish is dime or mellon sized! When you take your car in for a repair, you have every right to complain if damage is done! Thats why I ALAWAYS do a walk around with a service rep. when I drop any of my cars off for anything! These days you have to! Many people just dont give a darn! And if they do damage, most just hope you just wont notice, and will argue with you if you do! I'm sorry, but it just galls me to hear people advising you to lay down on this. And again, I'd avoid that shop, they have already proved their incopentece, why take chances...
                          Anyway, thats just my two cents
                          R--
                          Last edited by Markus Kleis; Aug 6, 2009, 02:07 PM. Reason: Family friendly language
                          • #43
                            The answer is simple. Wash the hood with soap and water and dry completely. Wet sand the hood with 1500 sandpaper. Wash and dry the hood again. Then sand the hood with 3000 grit sandpaper. Wash and dry the hood.Let the paint breath overnight,This will allow the solvent to escape and wont fight the compound your putting on top. Now for buffing use a wool pad with your compound of choice Once the compound step is completed wash the hood and dry. Now switch to a foam pad and use the machine glaze or polish of your choice.. Wash and dry then follow with the hand glaze of choice (3M 5941). Always use 70/30 blend microfiber towels throughout the process. This has worked for me on Sikkens and any brand of Clearcoat for many years and delivers a show quality finish.
                            Paint is naturally a solid we add thinners or reducers to make it spray able so we can apply it. as it is sprayed it drys from the out side in if not applied properly you can trap solvent. when this happens the solvent works its way to the surface and will fan out this causes blushing or what we call dye back. If there is too much solvent trapped it can build up and pop like little pin holes thru the clear.
                            When you wet or even dry sand the clear you open up the surface and allow solvent to escape. than after buffing you have improved the clarity.
                            • #44
                              runester, it's an honor to have your very first post explaining your ordeal posted in a thread I created. I TOTALLY understand your frustration and I can definitely relate to it.
                              I think legal action was not required in my case as the corporation was really cooperative in correcting my problem. I admit that the final result of my hood was not OEM perfect, but that is something I can correct myself with some ultra fine wetsanding paper. Sure, I should not have to incur the costs of doing any follow-up work, but that's just life.
                              The job performed on my car isn't too bad honestly. They used one of the best paints in the industry, Sikkens. They could have done better by simply wetsanding and polishing the paint after the paint job, but whatever... It's hard to sue every corporation that I unhappy with.
                              • #45
                                SHYNEMAN123, the answer you gave is "simple" if, and only if, you are very skilled in the art of wet sanding and rotary buffing. Otherwise it can be an extremely complex and involved process, not without potential pitfalls. Especially for a novice. Heck, a novice shouldn't even consider this!
                                Now, the_invisible, we aren't calling you a novice - in fact we aren't completely sure just what your skill level is, we just don't want a novice to read this and think it's perfectly fine and easy to just start wet sanding on their new paint job.
                                Back to the issue at hand - it appears that there is now an appearance difference present between this freshly painted hood, the previously painted bumper, and the original paint on the fender. But only the bumper has been polished with M205, and we know what M205 can do for the clarity of a finish. Before jumping in with the sand paper, no matter how skilled you may be, we would suggest you give those panels that have not been introduced to M205 a little love and see where that gets you. Obviously you aren't going to literally change the color, but if M205 darkened and deepened the appearance of that panel, well, you see where this is going.
