Diluting #00 for wetsanding?
  • Diluting #00 for wetsanding?
    I have picked up some 2500 grit paper along with the 2000 grit sanding block so I can touch up a deep scratch in the quarter panel of my XR4Ti.
    I remember from the classes at Meguiars that they suggest using #00 as a lube for wet sanding. I have picked some up, but I am not sure what the dilution ratio should be. I'll be using a bucket to soak the paper and a spray bottle to lubricate the paper while sanding.
    1992 Mustang 5.0L turbo notchback
    1986 Merkur XR4Ti 2.3L turbo
    1998 Explorer 5.0L
    Re: Diluting #00 for wetsanding?
    The Hi-Tech car wash? Maybe just the same dilution recommended on the label for car washing?
      I am pretty sure it is the same as for car washing.
        just a drop. It's to lube up the water in your container. Not for "use".
        Use QD as your lube, UQD or soapy water in a spray bottle, again just a drop or two.
