newbie , wet sanding fresh paint
  • newbie , wet sanding fresh paint
    Hey Guys,
    new to the forum. Already learned alot, just from poking around here.
    Got a question, Hope I'm posting in the correct area.
    I just completed a fresh paint job on a customers motorcycle.
    Looking to wet sand and buff the parts . Wag going to use 2500 wet. what polish will be best? And as the parts are smaller ( tanks, fenders) Can I use a wool bonnet on a DA? Or try to use the rotary ?
    Thanks guys,
    keep polishing
    Re: newbie , wet sanding fresh paint
    Hi and welcome to Meguiar's Online!
      Hello and welcome to mol.
        Sounds like you never used a rotary.
        Pay for the shipping and i'll give you my 6 inch Ryobi orbital
        regardless you need to use an oribital no bigger than 6" maybe a 4"
        WEN brand makes a manuevable small buffer, if you are doing lots of bikes or small parts like that- would be a good investment.
        One more thing- Is your paint suitable for buffing/polishing.
        You are on track with the 2500 grit though. As long as the paint is able to polish.
        To do so- it's either Epoxy, Polyester or Lacquer?? or enamel with hardener?
          Hello and welcome
          #86 solo cut & polish cream is awsome and will work well to remove 2500 g as i found out a long time ago buffing small parts is a 2 person job you need a holder. I use a 3" rotary for small jobs but it can be done with larger just alot more care and slower speed helps.good luck and post pics
            Uther,
            Welcome to the site. I am also very new here. I have painted literaly hundreds of tanks. I would recommend building your self a fender and tank stand. It does not have to be pretty just sturdy . I have never used a Da for buffing. I use my 8 inch with three different foam pads for different cuts. I have not used a wool pad since I used my first foam pad. I also use 2500 meguiar's paper. I would like to try the da some day for buffing just to check it out, but for now I just do what has worked for years. Oh yea, watch your edges and speed on the front fenders. It is possible to catch the edge and bend a steel fender.- good luck-
              Welcome to MOL.
                yes the paint is o.k to be polished. It's PPG base w/HOK Marblizer, 3 coats of HOK Blue Kandy , finished with PPG DC3000 .
                Didn't even think about catching the fender.. Thanks for the heads up.
                  Decided to go with a Rotary Buffer , and keep my fingers crossed and go slowly, I've buffed out hoods etc, but never worked on smaller parts like this..
                  thanks for all the advice
