Tracers or Swirls? Which one?
  • Tracers or Swirls? Which one?
    I sanded the roof of my car with 2000 grits > meg 85 + w4000 > meg 83 + w7000 > meg 80 + w7000.
    Every thing possible to prevent tracer was applied BUT at the end the tracer is there
    My question now is how to get rid of them? shell I use finer grits like 2500 or 3000?
    Re: Tracers!!!
    There are two ways to do this by hand,
    Re-sanding the entire area using a finer grit paper and then re-compound and cross your fingers
    Use the technique called "Feathersanding" outlined here,
    Feathersanding
    It's tedious work but the idea being you're only instilling sanding marks on the tracers and not over the entire surface.
    The way we usually remove tracers and RIDS, (Random Isoloated Deeper Scratches), is with an advanced technique that I call Feathersanding, which requires the use of Meguiar's Unigrit Finishing Papers and a rotary buffer.
    Experience helps a little too! Below are some pictures from a Side-by-side, before & after demonstration I did for the 2002 Bimmerfest in Santa Barbara. First I used a rotary buffer to buff out one half of the car and remove all of the light scratches. Next, I took little postage size stamps of Nikken Finishing Paper and sanded each individual scratch till it had been removed. Next, I used a compound to remove my sanding marks. The results were a scratch-free flawless finish on a 1991 e34 BMW M5.
    How To Remove Random Isolated Deeper Scratches using the Feather Sanding Technique
    Before
    I compounded the entire finish before starting the below process to remove the shallow scratches and expose the deep scratches.
    Process
    Random, Isolated, Deeper Scratches, (RIDS), can be removed, but it is an advanced technique that takes skill, patience and the right products to accomplish successfully. (A little luck helps too!)
    Do you own a rotary buffer and do you know how to use it?
      Re: Tracers!!!
      Thanks Mike for your fast reply!
      Do you think it's fine to sand it with just 3000 grit or have to start with 2500 and then 3000?
        Re: Tracers!!!
        #3000 grit is like sanding with paper, it has it's place but if you need to remove tracers, perhaps look at #2500 and cut up a lot of postage stamp pieces as they won't cut for long when doing this kind of work, let the paper do the work that is use light pressure and some soap in your water to lubricate the surface.
        If you push hard, you could run into the same problem.
        This kind of work is truly an art form, not merely a step-by-step process.
        Good luck...
          Re: Tracers!!!
          The tape off is a Masterpeace - Craftmanship - looks cool.
          The way a person treats their car is a direct reflection of how they treat themselves
            Re: Tracers!!!
            Why do I need to cut the sanding paper into pieces if the tracers are all over the hood?
              Re: Tracers!!!
              You titled your thread "Tracers", you called your problem tracers, we made the mistake of asuming you had tracers, now it sounds like you have sanding marks. Tracers are isolated and random, not all over the place, when you have scratches all over the hood this is called sanding marks.
              You need to go back and re-compound the hood and try to do a better job or removing all of the sanding marks. You could try re-sanding with a finer grit paper first.
              Is this a factory paint job? Or a repaint?
              Have you ever done this before?
              No one ever said wet sanding and compounding was easy. No one on this forum ever recommends or has recommended wet sanding factory baked on paint because in most cases the paint will be so hard that it will be extremely difficult to remove your sanding marks no matter how good you are at this procedure. Besides that factory paint is thin so you run the risk of removing too much clear film build in the process and ruining everything you're trying to accomplish in the first place.
                Re: Tracers!!!
                here a photo of the hood
                look how the swirls go in one direction, actually the sanding direction
                  Re: Tracers!!!
                  There's a huge difference between traces, sanding marks and buffer swirls, what the photo shows is buffer swirls also referred to as holograms.
                  Which problem are you trying to solve?
                  If the sanding marks have been removed and all you have now are buffer swirls, then that's easy to fix!
                    Re: Tracers!!!
                    others photos
                    great sanded factory fender waiting to be waxed!!
                      Re: Tracers!!!
                      Mike how do you differanciate between normal swirls caused by daily driving and buffer swirls?
                      what products you recommend to hit it with?
                        Re: Tracers!!!
                        Swirls instilled by a rotary buffer tend to have a pattern to them, like this for example,
                        Before
                        After
                        After re-reading your first post,
                        It appears as though your applying all of these products with a rotary buffer and your finishing with a cutting pad, the W-7000 is a cutting pad. This is why you have swirls in your car's paint. You need to re-polish each panel using a less aggressive pad.
                        At this point a good pad and product combination would be M83 with a W-8000 or W-8006 polishing pad. Even after this you're likely going to still see some swirls because of the direct rotating action of the rotary buffer. The best way to get a swirl free finish is to make your last step an application of a cleaner/polish using a dual action polisher like our G100. That said it's made for 110 volts, so we're not sure if it will work for you in Bahrain
                        Do you have access to some polishing or finishing pads?
                        The W-7000 foam cutting pad is a pretty aggressive pad to try to finish of a car with...
                        We're sorry we didn't catch this right away but at the time we were posting to this thread we were also setting up for a Saterday Detailing Class.
                        p.s.
                        We have another forum member in Bahrain, perhaps you guys can get together and exchange some tips?
                        Here's his forum name
                        great adventure
                          Re: Tracers or Swirls? Which one?
                          Actually I end up with w8000, I made a mistake in my post, anyway I will buff it with Meg 83 then Meg 80 with w8000 pad and I will post the results.
                          Thanks Mike
                            Thanks Mike
                            You're still going to have swirls when your done. You need to do one of two things and in a perfect world both.
                            After your last rotary buffer step you need to either buff the paint out by hand or use a dual action polisher to work-out the swirls instilled by the rotary buffer.
                            Either or, your choice.
                            Using a dual action polisher will work better, be easier and faster then trying to use your 4 fingers pushing down on a applicator pad and trying to remove swirls out of the clear coat paint.
                            The next thing you want to do is to apply some wax. Wax will protect the paint and it will also help to fill-in any swirls you couldn't remove.
                              What if I used w9000 with Meg 80?
                              Can Meg 80 be used by hand?
