Wetsanding
  • Wetsanding
    Can this be done with the Cyclo, and sanding disks attachments, with the same results as the air palm sander.
    Booby
    See it gleam
    It's lonely at the top, so you better take someone with you.
    Re: Wetsanding
    I am not sure, but do you think it would be hard to wet sand a carbon fiber hood and then clear coat it
      Re: Wetsanding
      I have NO experience with wet sanding except touch-up paint. I am going to take the panels off my old monte carlo and practice wet sanding, and using the tools. Just looking for anyone with experience with using the cyclo, as the sander with its attachments.
      Booby
      See it gleam
        Re: Wetsanding
        I know with the PC it does not operate as fast as a Air powered DA and may leave "pigtails" that are a little harder to remove.
        You left out licking the water off. Oh, wait a minute, that's my cat, not my car. Uh, I mean my cat licks himself dry. I don't lick my cat dry. Or my car. -PC.
          Re: Wetsanding
          Looks like I'll be reinvesting, at my wife's dismay I might add. I want to
          be able to get to water spots, and other things that I'm led to belive is
          done by wetsanding. How much water is in wetsanding ?
          Booby
          See it gleam
            Re: Wetsanding
            Have you tried chemical cleaners like.
            Deep Crystal Paint Cleaner
            ScratchX
            Quik Clay System
            Wetsanding you want to do as a last resort.
              Re: Wetsanding
              Wet sanding, especially by a beginner is best done on a scrap body panel and by hand.
                Re: Wetsanding
                I have tried them, maybe I'm not calling the defect by the right name. I did use the term, water spots. But I will try by hand though, good idea huh? Thanxs.
                Booby
                See it gleam
                  Re: Wetsanding
                  Don't think there's a readily available sanding system to attach to the Cyclo, plus it probably wouldn't work very well.
                  Sanding is the last option for repairing below surface paint defects, before tackling what most would agree is the most difficult and filled-with-risk process, perhaps invest in a dual action polisher and try a cleaner/polish.
                    Re: Wetsanding
                    I agree with Mike. BTW, what kind of defect are you trying to remove?
                    As Mike said, this is your last option. This should be done in case you have very heavy oxidation, or something that is hard to remove with M85 (diamond cut compound) and a wool pad.
                    if you use a cyclo, you need a lot of experience to manage both buffing heads to do an even sangind cut. IMO, it doulw be better and safer to use a DA sander with a dry sanding method.
                    If the defect doesn't need sanding, use a rotary or a DA, whatever it's needed to remove it.
                    Hope this helps
