The paint on an old corvette shows visible signs of stress cracking. The car is a white 1969 and it was repainted sometime in the mid 70's using the same color and type of factory lacquer paint. I believe the original paint and the repaint were both made by DuPont.
Now if you have ever seen anything like this, you will know that the stress cracks are hardly noticed until you get into an exact angle of light. Actually, the car looks like a brand new car from a few feet away at most other viewing angles. The cracks appear to be on the surface as you can actually feel them with your fingernail. Also, the stress cracks appear to be more concentrated to the hood, roof and rear deck. The sides are relatively good.
In an very small inconspicuous area, I tried using a polishing pad and an agressive compound by hand. I was somewhat surprised to see that the cracks appeared to be almost completely removed with very little effort. So I am now wondering what the results might be going with a wet sanding process.
Any comments on wet sanding an old repainted corvette?
