RV Wash Tools
  • RV Wash Tools
    Here are 2 tools I consider a must for washing an RV. Both are on telescoping handles. The soft brush can be found almost anywhere. The squeege I found at an RV rally. It is a head with a piece of soft foam folded over double making 2 edges for wiping. It cuts drying time dramatically!! I wipe up the runs with the Absorber and old bath towels. Typically, I wash one half of a side top to bottom then squeege it dry and move on to the second half. This helps prevent water spots since I am working alone.
    Barry
    Re: RV Wash Tools
    Those are the same ones I use for aircraft.
    AeroCleanse, LLC
    www.aerocleanse.com
      Re: RV Wash Tools
      Thanks for sharing this with our Forum Community Barry.
      A big part of any job we all do is the tools that help us to do the work and usually the biggest problem with tools is knowing which ones to get and where to find them, so thanks for sharing what's working for you.
        Re: RV Wash Tools
        Looks good, I will have to find some.
          Re: RV Wash Tools
          I like that foam squeege... And I bet youre proud of that CAT sticker arent you? I know I would like to have a big CAT diesel.
          Whats the temp reading outside?
            Re: RV Wash Tools
            All you need now is this - PORTER CABLE on a STICK!
              Re: RV Wash Tools
              Proper tools for the job, make life so much easier.
