Wow, first post here in around 6 years! I guess after my detailing class with Rod Kraft, I didn't have many questions left!
But now I do have one!
I while back, I "inherited" a rotary buffer that's basically identical to this one (link). It has a 5/8" threaded shaft (if my outside micrometer is right) with two flat spots at the base of the shaft, where the rubber backing plate locks in. The backing plate slides on, and you have a circular "nut" that locks it down.
I've been able to achieve some pretty good results with it (its main use so far has been restoring cloudy headlight lenses with PlastX), but it uses those old-fashioned pads that wrap around the backing plate and tie with a string. They're annoying to say the LEAST! They get a bit off-center, the buffer goes out of balance, and it shakes your arms off.
So, I've been looking for a self-centering solution, something like the Meguiar's backing plate (link), but I'm not sure if it'll fit my buffer.
Anyone have any recommendations?
