How you use a rotary buffer, your technique, can impact your results during defect removal. Sounds obvious, right? So which technique is right? Therein lies the rub - various techniques are used around the world to achieve essentially the same result, but those techniques vary for different reasons, and the goal of this article is to explore both how and why techniques vary and why it's important to you.
Let's start with a quick look at where technique fits into the greater world of paint polishing variables, and then we'll break down that term "technique" and look a bit more in depth into how and why it matters.
10 Things That Impact the Results While Machine Polishing Paint
So technique is just one of several variables in the overall process, but we can break technique down to 5 synergistic variables that can be adjusted by the user. Why "synergistic"? Because these variables, all of which can be controlled by the user, are interdependent and interrelated - they all work together to impact polishing results. These variables are:
Arm Speed
Slower arm speed
Faster arm speed
Larger area being worked
So now you have a clearer understanding of how different techniques impact the buffing process and how you can both minimize problems and maximize results by varying your technique. You may be thinking "but isn't there one ideal technique?" In reality you need some variation in technique at times, for a variety of reasons. Severity of defects, hardness of the paint, even the climate and customer expectations might cause you to adjust your technique from time to time. And with the tremendous variations in paint systems out there, if you do the same thing on every car every time, you will miss the mark half the time. The best detailers are able to adjust their process in order to address all of these variables, and they understand the impact of each change they make to that process. They're able to "read the paint" and adjust their technique accordingly.
Lastly, now that you can dissect buffing techniques you can watch others and better learn and understand what's actually happening. You can identify your own technique and adjust it with precision. Most importantly, you can expand your capabilities and improve your skills. No go out there and polish some paint.
We would be terribly remiss if we didn't give credit to Jason Rose for his vast knowledge on this topic. Jason has travelled the world, literally, working with body shop techs and detailers in places as varied as Germany, Brazil, Australia, China and of course all over North America. He's seen every type of paint system imaginable, and he's seen every technique you can think of (and some you probably can't!!). His observations have allowed him to distill down the generalized techniques used in different parts of the world. To that end, for you really hard core fanatics who can't get enough info when it comes to detailing, we'd like to share the following observations on buffing technique from around the world, with a little explanation of each. A little disclaimer first - the techniques we outline for each geographic area are what is prevalent in each area in a body shop environment and are not meant to imply that everyone does everything exactly the same way. But there are definite differences in technique from one part of the world to the next. We also apologize for the graininess of the following images as there are captures from short video clips.
Asia
Tool Speed: medium to fast
Arm Speed: medium to fast
Downward Pressure: medium
Pad Angle: on-edge
Application area: wide
Overall Aggressiveness (scale of 1-5 with 5 most aggressive): 4
____________________________________________________________________________________________________
Western Europe
Tool Speed: slow
Arm Speed: fast
Downward Pressure: light
Pad Angle: flat
Application area: small
Overall Aggressiveness (scale of 1-5 with 5 most aggressive): 1
South America
Tool Speed: fast
Arm Speed: fast
Pad Angle: heavily on edge
Application area: very wide
Overall Aggressiveness (scale of 1-5 with 5 most aggressive): 3
United States
Arm Speed: medium to slow
Downward Pressure: strong
Pad Angle: slightly on edge
Overall Aggressiveness (scale of 1-5 with 5 most aggressive): 5
- The tool being used
- The product being used (compound, polish, etc)
- Supplemental wetting agents
- Buffing pad
- Backing plate
- Paint & substrate
- User technique - the subject of this article
- Environment
- Time & expectations
- User attitude
Tool Speed
Tool Speed
- [*=2]variable speed settings will alter cut of any pad/product
[*=2]the lower the speed, the less the defect removal
[*=2]the higher the speed, the greater the defect removal
[*=2]high speed generates more heat on the paint
[*=2]high speed causes more swirls
[*=2]low speed indicates more control
[*=2]low speed generates less heat and fewer swirls
[*=2]rotary speeds are measured in revolutions per minute (rpm) while DA speeds are measured in oscillations per minute (opm)
[*=2]Meguiar's recommends never spinning a rotary at speeds in excess of 2,000 rpm when polishing paint
Arm Speed
- [*=2]defined as the rate at which the tool is moved across the paint
[*=2]slow arm movements allow for more time spent buffing in a given spot, and defect removal is increased
[*=2]fast arm movements allow for less time spent buffing in a given spot, and defect removal is decreased
[*=2]fast arm movements can also increase the risk of holograms
[*=2]faster arm movements give a false perception of working faster
Slower arm speed
Faster arm speed
Downward Pressure
Lower pressure - note how the backing plate is practically sitting on top of the pad
Greater pressure - note how the pad is now compressed under the backing plate and actually curling up over it
Pad Angle
Pad flat to the surface
"On-edge" buffing
Application Area
Downward Pressure
- quite literally, how much pressure the operator is applying directly over the pad
- the lower the pressure, the lower the rate of defect removal
- the greater the pressure, the greater the rate of defect removal
- increased pressure will also increase heat generation, and the heat can rise dramatically and quickly, leading to the very real possibility of paint burn
Pad Angle
- quite literally, the angle of the pad face relative to the panel
- "on-edge" buffing yields more swirls and provides less defect removal
- "on-edge" buffing gives a false perception of more aggressiveness/faster defect removal, mostly due to increased downward pressure being applied
- a flat buffing pad products less swirls and more defect removal
"On-edge" buffing
Application Area
- [*=2]this is the size of the area being worked for a given amount of product; also known as a work section
[*=2]a larger application area provides....
[*=3]less defect removal
[*=3]less control
[*=3]less consistency
[*=3]potentially more swirls
[*=2]a smaller application area provides....
[*=3]more defect removal
[*=3]greater control
[*=3]greater consistency
[*=3]less swirls
[*=2]area size should be roughly equal to the shoulder width of the operator
Small area being worked
Asia
Pad Angle: on-edge
- Technique follows relatively softer paint
- Lots of paint defects
- Body shops tend to sand full panels
- Commonly used pad is large diameter foam
Western Europe
Tool Speed: slow
Arm Speed: fast
Pad Angle: flat
- Least aggressive technique in the world
- Technique follows high tech painting processes and progressive polishing products and tools
- Body shops tend to do only spot repair sanding
- Commonly used pad is small diameter foam with thick backing plate
South America
Tool Speed: fast
Arm Speed: fast
- Technique follows old school practices and lack of high tech compounds in the market
- Commonly used pad is large diameter wool
United States
- Most aggressive in the world
- Body shops show a mix of spot repair and full panel sanding
