Instrument Cluster Correction Vs M205
  • Instrument Cluster Correction Vs M205
    Today appeared a work somewhat unexpected.
    A customer bought his Toyota Hilux 2009 a few months ago I asked if it would be possible to remove spots and stains from the instrument panel.
    Initial state of the instrument panel
    Apparently these tags are acid detergent spilled on the panel...
    probably when "someone" sprayed this product on the hinges of the doors.
    Starting the dismantling of the dashboard
    After we decided to inspect the removal with the aid of lights (Brickmann Dual Xenon and LED 950 Lumens), under the lights the state was worse than it seemed!!!
    everywhere stains and scratches!!!
    Removing plexiglass display of the instrument panel ...
    After 3 1/2 hits... end approximately 40 minutes... We arrive at this result ...
    Reinstalling the panel...
    Inspecting with lights after reinstalling...
    With the help of Brickmann Dual Xenon...
    With LED...
    With full turn on lighting panel...
    THAT ALL FOLKS....
    He isso ai pessoal!!!...
    Re: Instrument Cluster Correction Vs M205
    Great way to use M205!!! I'm glad to see it worked out for you.
    Did you try using PlastiX?
      Thank you ...
      Already used in other times PlastiX ... but in my personal opinion, I think the M205 spectacular!
        Did you apply 205 by hand?
          Hi Ronniejay,
          I used to do this job Makita 9227 - 220v, M20516, 3M UK Finishing Pad Blue 80mm, LC 2 7/8 Backing Plate and a very important item: much, much, much patience !.......
          Ate a proxima....
            Very impressive results!!
