So I've got the cheapo Harbor Freight rotary with Meguiar's 2.0 pads (cutting, polishing, and finishing pads), along with 105, 205, and D151.
I've got a heavily abused 1997 Chevy Lumina that I bout for the purpose of cleaning up and reselling. It's never seen polish or wax, and was probably only washed a few times each year. Major defects requiring heavy correction. Fortunately, it's a cheap car in horrible shape, so nothing I do will make it look any worse. I've spent 6 hours on it with the rotary, and at this point I'm just frustrated.
Using the cutting pad and the 105, I'm able to remove 99% of the surface scratches and swirls, but no matter how I try to adjust my technique, I'm putting holograms everywhere.
I prime the pad with 2 squirts of QD, use a small amount of 105 (maybe half a teaspoon), work a 16"x16" section at a time, and work the product for about 1 min before I wipe (80 degree weather and working in the shade). I clean my pad on the fly every 2 sections. I've used speed settings from 2 to 3 and a half. I've tried keeping the pad completely flat on the car, but the rotary wants to hop and go flying everywhere if I try to let it glide over the surface and don't bear down on it with some force. I've tried tilting the rotary up slightly where I'm just working with the right half of the pad (this let's me glide over the surface gently but still puts severe holograms in).
Ya know how when you're cutting you can see the holograms going into the surface while you're working the product? If I'm moving the buffer from right to left, I'm getting a nice, smooth, even action that doesn't put holograms in, but when I go on the "back stroke" from left to right, its leaving a line every time, and that's where my holograms are being created. Also, I know I'm supposed to be going up and down for 2 passes, then side to side for 2 passes, but how in the world do you control the buffer when moving forward (away from your body) then back? Every time I try this, the buffer wants to grab, bite, and jump all over the place. Should I be holding the buffer completely flat and bearing down on it with just enough pressure to control it, or should I be gliding across the surface? Should I be slightly tilting the pad and just using the right side of the pad on the paint? After I've buffed for 30 seconds to 1 min, should I spritz the surface with water and make 1 or 2 final passes? How do you effectively go front to back and back to front? How do you go from left to right?
Experts, let loose and impart some knowledge. I'm like a Sham Wow, ready to soak it up.
