Fight or Flight Method for Gaging Surface Temperature
  • Fight or Flight Method for Gaging Surface Temperature
    The topic of heat comes up often when talking about using a rotary buffer to machine compound or polish paint. For decades now I read comments by people where they state heat is necessary when using a rotary buffer with a compound, or any other abrasive product that uses diminishing abrasives for abrading ability, in order to break the diminishing abrasives down. This is not accurate.
    When buffing with a rotary buffer and any type of product that contains diminishing abrasive, including a compounds, paint cleaners, cleaner/polishes and even a cleaner/waxes, what's necessary is pressure over time. Heat is just an unnecessary and unwanted byproduct of the process.
    When using a rotary buffer for correction work for even a minute or longer, heat is unavoidable. The smaller the section your work the greater the risk of getting the paint hot. It's normal and okay to get paint warm, (because there's nothing you can do about it), but you don't want to get paint hot and if you do get paint hot then you want to stop buffing in that section and let the paint cool down. So the question is,
    How hot it too hot?
    Or
    What temperature range is consider warm and within a range that's safe to work a rotary buffer?
    I don't know any specific temperature ranges recommended by any of the major paint companies to work within or extreme hot temperature ranges to avoid, so here's the common sense approach anyone can use on-the-fly when buffing with a rotary buffer. This is a method I've been using since I started using a rotary buffer in the late 1980's and that I've been teaching in any class that includes using a rotary buffer. It's simple, yet effective and you don't need to purchase any testing tools as you already have the tool you need built-in.
    This method works off your hand's sense of touch and your brain's instincts to protect you. I call it the Fight or Flight Method for Gaging Surface Temperature. Not one of my better titles but descriptive to say the least.
    The Fight or Flight Method for Gaging Surface Temperature
    When using a rotary buffer, periodically check the temperature of the paint by placing the palm of your hand flat on top of a section you just finished buffing, like this,
    If the paint feels warm, even close to hot, BUT it's not so hot that you jerk your hand away, then it's in a temperature range that's safe to buff.
    If you you place your hand on the paint and your Fight or Flight instinct takes over an you find yourself jerking your hand away from the surface at the speed of light, then the paint is too hot and you should stop buffing that section and allow the paint to cool down.
    Kind of caveman but you get the idea. The bigger point is to check the surface temperature of the paint once in a while because you might surprise yourself at how hot you're getting the paint. Because you're in control of the rotary buffer you need pay attention to the surface temperature and this means pausing for a moment to feel the paint.
    Different body panel materials, for example steel, aluminum, fiberglass, composite, will heat up at different rates and will either dissipate or hold heat at different rates, so it's a good idea to check each time you work on a different car.
    With testing, you can get a feel, (not pun intended), for how long you can buff an average size section and not be getting the paint too hot.
    Re: Fight or Flight Method for Gaging Surface Temperature
    Great advice Mike
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
      It's actually really simple advice but sometimes the little things are the big things.
      I know I've been surprised once in a while when I've felt the paint surface after buffing for short times so I figured other's may not have thought of this simple test so I wrote it up.
      It was also an answer to a question on another forum.
        It does make a lot of sense. I agree it is something a lot of us probably do not think about as much as we should.
          Great info. I've been learning the rotary for a couple months now and when I first started I used this method, good to know now that I was assuming correctly. I worked my test panel very hard in a very small area to see just how hot the paint could get, how much damage could be done, and how quickly. I was amazed at how hot I got it, pulling away at light speed about summed it up, and sure enough I saw a paint burn once the panel cooled. It was interesting how long it took though, the rotary isn't near as dangerous as implied, assuming you are paying attention. It took 3000rpm in a 10"x10" area for about 15sec to get that hot. As long as I stay moving I've never gotten a panel anywhere close to that temp again.
          And yes, I understand there are 1,000,001 other factors to heat and damage with the rotary, it's just the online forums seem to act as though this is far more common than this .
            If you want to go the hi-tech route, I have been thinking about getting this
            Cen-Tech Non-Contact Laser Thermometer
            Instantly measure temperatures in automobile engines or other machinery by simply pointing the laser.
            * Professional quality, German infrared technology at an excellent value
            * Temperature range: -4°F/-20°C to 968°F/520°C
            * Distance to spot accuracy: 8 to 1
            * Single circuit chip design prevents jamming
            * Celsius/Fahrenheit LCD display with backlighting
            * Accuracy: +3°F/+2°C or 2% of reading
            * Nonslip cushioned grip
            Harbor Freight Tools
            . Normally $60, on sale until Jan 10 for $27 (with coupon from last Sunday's paper)
