After a couple days of practicing on my junk yard panels, I finally began work on "restoring" the paint on my truck and I have a few questions. I'm working on a 1996 F series with the original clear coat paint. I'm using a DW849 rotary and a G100 along with D151 Paint Reconditioning Cream and 6.5" Meguiar's foam polishing and cutting pads. No wool pad - yet. I've been using the foam cutting pad with the D151 on the rotary at 1,800 rpm. Buffing an area 4-5 times with moderate pressure applied seems to produces pretty good results. I would say 90-95% of the swirls are gone and the RDS are greatly minimized.
Now the questions.
1. What would be the next step up in aggressiveness from this point? I have to apply fresh product to the same area many times to get the swirls out. It's working, but is very time consuming and I'm going through a lot of product. I see my options as turning the rotary speed up a little more, switching to a wool pad, or switching to a more aggressive product.
2. After using the rotary at 1,800 rpm with the foam cutting pad and D151 the finish looks very good without any buffer trails or holograms. I have followed this with the G100 using a polishing pad and the D151, but it doesn't seem to have any affect on improving the finish further. Not that I'm complaining, but from all that I've read here it doesn't seem possible that I should have a near perfect finish after "cutting" with a rotary. At least not as a beginner. Any ideas?
Thanks,
Shawn
Now the questions.
Thanks,
Shawn
