When to switch products and machines
  • When to switch products and machines
    Hi guys, 1st time poster here and new to Meguiar's products. Please direct me to another thread if this has been covered before.
    I'm working on an '05 Silverado, black, with the usual swirls and tiny scratches. Did a test spot and found it takes #83 and an 8000 pad on the rotary to remove 99% of the defects. That's about as aggressive as I want to get with it as it's a daily driver/work truck.
    So here's the question: Is it recommended to do an intermediate step between #83/8000/rotary and #80/8000/DA ? And if so, is it better to use the less aggressive product with the more aggressive machine (#80/rotary) or the more aggressive product with the less aggressive machine (#83/DA) ?
    Or put another way, will #80 and the DA remove the slight swirls/holograms left by #83 and the rotary? I know, the only way to find out is to try it, (your mileage may vary), but I was wondering what others might have experienced and would recommend.
    Thanks in advance. I really like the forum and the products too!
    I saw it on the Internet...it must be true!
    Re: When to switch products and machines
    Hi and welcome to Meguiar's Online.!
    Originally posted by ShinyChevy View Post
    So here's the question: Is it recommended to do an intermediate step between #83/8000/rotary and #80/8000/DA?
    It all depends on the paint, if you give a pass with #80 and it mars the paint then I think you should hit it with a less aggressive product. If #80 leave the paint finish fine then it's not necessary.
    is it better to use the less aggressive product with the more aggressive machine (#80/rotary) or the more aggressive product with the less aggressive machine (#83/DA)?
    Well if you tried #83 with the DA and the results weren't as expected the you should use #83 with the Rotary and it could be followed by #80 with the DA
    Yes
    Good luck!
      I forgot to mention, maybe you could read this for information purpose.
      Learning to use the Rotary Buffer
        Thanks for the reply.
        Answered the question myself today: No, an intermediate step was not necessary (in my case anyway). On my test panel - the hood - thorough buffing with #80 and the DA after the rotary work produced a beautiful hologram free finish.
        That said, I did one anyway. I used the DA and #83 on places I couldn't or didn't want to do with the rotary, and then, before I changed pads, I went over the big panels too. Followed up with #80 and WOW! Even better than I was shooting for!
        I'm very pleased with the switch to Meguiars products - easy to use, work as advertised, and the support is great!
