It looks like it's going clear way to fast and coming to a dry panel ... Am I not using enough product? It's only like 15 seconds in a 12 inch workspace. I'm not sure if my polishes have gone bad either I have had each for a couple years now. I use one line about 8 inches long for product at about 1200 RPMs and work that section. I started notice the problem on the top of a 1992 LX Mustang fender which very small in width. Could it maybe be my technique?
Polish Breaking Down to fast?
You don't say which polishes you're using, but the fact that you've had them for two years and you're just now complaining about fast drying tells me there's a problem with the product. I say this because, if you've been using the same technique with these polishes for two years, have been getting good results and are just now having a problem, the state of the product seems to be the only thing that has changed.
I should say that I have very little experience with the rotary (almost none, in fact!), but am just trying to think this through logically.Michael Stoops
#83 and #80. I decided yesterday to apply #80 via PC as a test to make sure the product was ok and it worked great.. I got about 2 1/2 minutes of play time time out of it. With the rotary I'm lucky to get 20 seconds before the surface appears to start getting dry
I say make sure the surface you are working on is not hot. I find that if I work on a hot or warm surface my polish breaks down really quickly.You left out licking the water off. Oh, wait a minute, that's my cat, not my car. Uh, I mean my cat licks himself dry. I don't lick my cat dry. Or my car. -PC.
When the tempature here is above a 100, my #80 and #83 seem to break down faster. I was under a carport the whole time, but the air tempature was just hot. I will see if my theory is correct this weekend. The tempature here is suppose to be in the upper 80's w/ low to moderate humidity.2016 Focus ST
